[snappyHexMesh] stl file not showing after snappyhexmesh
Old   February 22, 2023, 10:21
Default stl file not showing after snappyhexmesh
cfdnsh is on a distinguished road
Hello, I tried to convert an stl file using snappyHexMesh. I had no errors running blockMesh > surfaceFeatures > snappyHexMesh but then when I opened the file in paraView it only shows my blockMesh region. Below are my codes, can anyone spot the problems?
blockMeshDict
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 100;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 1)
    (1 0 1)
    (1 1 1)
    (0 1 1)
blocks
    hex (0 1 2 3 4 5 6 7) (16 16 16) simpleGrading (1 1 1)
boundary
	patch0_half0
        type cyclic;
        neighbourPatch patch0_half1;
        faces
            (0 3 2 1)
    patch0_half1
        type cyclic;
        neighbourPatch patch0_half0;
        faces
            (4 5 6 7)
    patch1_half0
        type cyclic;
        neighbourPatch patch1_half1;
        faces
            (0 4 7 3)
    patch1_half1
        type cyclic;
        neighbourPatch patch1_half0;
        faces
            (2 6 5 1)
    patch2_half0
        type cyclic;
        neighbourPatch patch2_half1;
        faces
            (3 7 6 2)
    patch2_half1
        type cyclic;
        neighbourPatch patch2_half0;
        faces
            (1 5 4 0)
surfaceFeatures
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      surfaceFeaturesDict;
surfaces
    "volume3.stl"
    "inlet3.stl"
    "outlet3.stl"
    "walls3.stl"
includedAngle   150;
subsetFeatures
    nonManifoldEdges yes;
    openEdges        yes;
trimFeatures
    minElem         0;
    minLen          0;
writeObj        yes;
snappyHexMeshDict
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
castellatedMesh on;
snap            off;
addLayers       off;
geometry
    volume
        type triSurfaceMesh;
        file "volume3.stl"
    walls
        file "walls3.stl"
    inlet
        file "inlet3.stl"
    outlet
        file "outlet3.stl"
    refinementBox
	 type searchableBox;
	 min (-1.0 -0.7 0.0);
	 max (8.0 0.7 2.5);
castellatedMeshControls
    features
//      { file "volume3.eMesh"; level 2; }
    refinementSurfaces
        volume3
            level (2 2);
            patchInfo { type wall; }
            regions
                <inletRegion>
                    level (2 2);
                    patchInfo
                        type patch;
                        inGroups (inlet);
                <outletRegion>
                    level (2 2);
                    patchInfo
                        type patch;
                        inGroups (outlet);
    refinementRegions
        volume3
            mode    inside;
            level   2;
    insidePoint (0.50 0.50 0.60); // Offset from (0 0 0) to avoid
                                     // coinciding with face or edge
    nCellsBetweenLevels 3;
snapControls
//  explicitFeatureSnap    on;
//  implicitFeatureSnap    off;
addLayersControls
    layers
        "volume3.stl"
            nSurfaceLayers 2;
    relativeSizes       on;   // off, usually with firstLayerThickness
    expansionRatio      1.2;
    finalLayerThickness 0.5;
    minThickness        1e-3;
//  firstLayerThickness 0.01;
//  maxThicknessToMedialRatio 0.3;
writeFlags
//    scalarLevels
    layerSets
    layerFields
mergeTolerance 1e-6;
cfdnsh is offline   Reply With Quote
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
