[snappyHexMesh] Surface feature extract problems
Old   February 21, 2023, 08:20
Default Surface feature extract problems
Will Amos
Will_amos is on a distinguished road
I'm currently working on my dissertation, using OpenFOAM on a 3D aerofoil. having alot of problems using both the surfaceFeatureExtract and snappyHexMesh when meshing my geometry. when opening the stl files i can see the aerofoil within the bounding box but after i run the above commands the geometry does not appear anymore. I'll copy the error messages below. Does anyone have any advice or tutorial videos which import geometries using solid works and meshlab?
| \\ / O peration | Version: 2106 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _40a7d5d6-20210727 OPENFOAM=2106 patch=211215
Arch : "LSB;label=32;scalar=64"
Exec : surfaceFeatureExtract
Date : Feb 21 2023
Time : 11:40:41
Host : DESKTOP-M9QLCCG
PID : 1094
I/O : uncollated
Case : /home/will_amos/OpenFOAM/aerofoil
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Note: Feature line extraction only valid on closed manifold surfaces
Reading surfaceFeatureExtractDict
ExecutionTime = 0 s ClockTime = 0 s
End
Many Thanks in advance for any help
Will_amos is offline   Reply With Quote
openfoam, surfacefeatureextract
Star CCM+ CHT surface mesh problems.. intersections wont go away. lelandt50 STAR-CCM+ 1 June 17, 2022 01:21
Error in gmshToFoam on ESI v2106 siefer92 OpenFOAM Programming & Development 4 July 17, 2021 06:11
[snappyHexMesh] unsteady flow around a square cylindier snappy problems triball OpenFOAM Meshing & Mesh Conversion 4 February 20, 2016 17:10
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
