February 18, 2023, 03:22 |
Geometry with Obstacles
Khan
Rep Power: 8 |
I am new to OpenFoam and also to GMSH.
I try to model an axisymmetric geometry for a sensible stratified heat storage tank. I need to define empty geometry at the inlet and outlet of the tank as obstacles (namely diffusers). Please see attached geo file; when I apply 3D meshing, it works but the diffusers also get meshed with the inner medium. Would you please help me with this issue? Kind regards. Hakan |
February 18, 2023, 23:07 |
Solution
Khan
Rep Power: 8 |
I could overcome this issue via subtracting the obstacle (empty) volume from the main medium volume by use of "BooleanDifference", see the code below for geo file:
SetFactory("OpenCASCADE"); // Inputs r_tank=2.56/2; // m - radius of tank r_pipe=0.075; // m - radius of pipe r_diff=0.8; // m - radius of diffuser h_tank=3.83; // m - tank height h_pipe=0.25; // m - inlet/outlet height h_such=0.13; // m - suction head t_diff=0.005; // m - material thickness (diffuser and pipe) h_diff=0.075; // m - diffuser gap height grid_s=1; // grid size // Geometry - Tank Point(1) = {0,0,0,grid_s}; Point(2) = {r_pipe,0,0,grid_s}; Point(3) = {r_pipe,0,h_pipe,grid_s}; Point(4) = {r_tank,0,h_pipe,grid_s}; Point(5) = {r_tank,0,h_pipe+h_tank,grid_s}; Point(6) = {r_pipe,0,h_pipe+h_tank,grid_s}; Point(7) = {r_pipe,0,h_pipe+h_tank+h_pipe,grid_s}; Point(8) = {0,0,h_pipe+h_tank+h_pipe,grid_s}; Line(1) = {1,2}; Line(2) = {2,3}; Line(3) = {3,4}; Line(4) = {4,5}; Line(5) = {5,6}; Line(6) = {6,7}; Line(7) = {7,8}; Line(8) = {8,1}; Line Loop(1) = {1,2,3,4,5,6,7,8}; Plane Surface(0) = {1}; // Geometry - Diffuser - Bottom Point(9) = {0,0,h_pipe+h_diff,grid_s}; Point(10)= {r_diff,0,h_pipe+h_diff,grid_s}; Point(11)= {r_diff,0,h_pipe+h_diff+t_diff,grid_s}; Point(12)= {0,0,h_pipe+h_diff+t_diff,grid_s}; Line(9) = {9,10}; Line(10)= {10,11}; Line(11)= {11,12}; Line(12)= {12,9}; Line Loop(2) = {9,10,11,12}; Plane Surface(1) = {2}; // Geometry - Diffuser - Top Plate Point(13)= {0,0,h_tank+h_pipe-h_such-h_diff-t_diff,grid_s}; Point(14)= {r_diff,0,h_tank+h_pipe-h_such-h_diff-t_diff,grid_s}; Point(15)= {r_diff,0,h_tank+h_pipe-h_such-h_diff,grid_s}; Point(16)= {0,0,h_tank+h_pipe-h_such-h_diff,grid_s}; Line(13)= {13,14}; Line(14)= {14,15}; Line(15)= {15,16}; Line(16)= {16,13}; Line Loop(3) = {13,14,15,16}; Plane Surface(2) = {3}; // Geometry - Diffuser - Top Inlet Point(17)= {r_pipe,0,h_tank+h_pipe-h_such-t_diff,grid_s}; Point(18)= {r_diff,0,h_tank+h_pipe-h_such-t_diff,grid_s}; Point(19)= {r_diff,0,h_tank+h_pipe-h_such,grid_s}; Point(20)= {r_pipe+t_diff,0,h_tank+h_pipe-h_such,grid_s}; Point(21)= {r_pipe+t_diff,0,h_tank+h_pipe,grid_s}; Line(17)= {17,18}; Line(18)= {18,19}; Line(19)= {19,20}; Line(20)= {20,21}; Line(21)= {21,6}; Line(22)= {6,17}; Line Loop(4) = {17,18,19,20,21,22}; Plane Surface(3) = {4}; // Union of Diffuser Surfaces // Plane Surface (4) = BooleanUnion{ Surface{1}; Delete; }{ Surface{2,3}; Delete; }; // Subtracting Diffuser from the Main Flow Body // Plane Surface (5) = BooleanDifference{ Surface{1}; }{ Surface{4}; Delete; }; // Rotating the Surface and Forming Volume (AxiSymmetric) Rotate {{0,0,1},{0,0,0},-2.5*Pi/180.0} { Surface {0}; } Extrude {{0,0,1},{0,0,0},5*Pi/180.0} { Surface {0}; Layers{1}; Recombine; } // Rotating the Surface and Forming Volume - diffuser (AxiSymmetric) // BooleanUnion{ Surface{1}; Delete; }{ Surface{2,3}; Delete; } Rotate {{0,0,1},{0,0,0},-2.5*Pi/180.0} { Surface {1}; } Extrude {{0,0,1},{0,0,0},5*Pi/180.0} { Surface {1}; Layers{1}; Recombine; } BooleanDifference{ Volume{1}; Delete;}{ Volume{2}; Delete;} Rotate {{0,0,1},{0,0,0},-2.5*Pi/180.0} { Surface {2}; } Extrude {{0,0,1},{0,0,0},5*Pi/180.0} { Surface {2}; Layers{1}; Recombine; } BooleanDifference{ Volume{1}; Delete;}{ Volume{2}; Delete;} Rotate {{0,0,1},{0,0,0},-2.5*Pi/180.0} { Surface {3}; } Extrude {{0,0,1},{0,0,0},5*Pi/180.0} { Surface {3}; Layers{1}; Recombine; } BooleanDifference{ Volume{1}; Delete;}{ Volume{2}; Delete;} Physical Surface("inlet") = {54}; Physical Surface("outlet") = {43}; Physical Surface("walls") = {44,47,58,57,55}; Physical Surface("wedge_1") = {45}; Physical Surface("wedge_2") = {46}; Physical Surface("diffuser") = {39,40,41,42,48,49,50,51,52,53,56}; Physical Volume("innerFlow") = {1} |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 03:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 14:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 22:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 04:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 14:49 |
