[snappyHexMesh] SnappyHexMesh add Layer Only failed |
January 5, 2023, 08:19 |
ff
Rep Power: 16 |
Hi Foamers,
I have got a problem. When I am using snappyHexMesh, if I use snappyHexMesh castellatedMesh, snap and addLayers in one roll, then mesh is ok. Code:
castellatedMesh true; snap true; addLayers true; Code:
castellatedMesh true; snap true; addLayers false; Code:
castellatedMesh false; snap false; addLayers true; |
January 11, 2023, 05:14 |
M
Rep Power: 13 |
I did this before and it worked as expected.
You state that you "get no layers". What settings are you using for the layer generation itself, what does the log file say? |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] Error defining boundary layer around cube snappyHexMesh | crizpi21 | OpenFOAM Meshing & Mesh Conversion | 5 | October 16, 2021 11:56 |
[snappyHexMesh] problem with snappyHexMesh | kanes | OpenFOAM Meshing & Mesh Conversion | 10 | January 26, 2016 07:11 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 15:46 |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 05:26 |
