[snappyHexMesh] Patches removed because to zero-size |
January 2, 2023, 05:47 |
Eleonora Gajetti
Hello everybody,
I'm trying a multi region mesh, where I have a solid part and a fluid part defined with two different .stl with patches. I define cellZones and faceZones for the two parts so to use splitMeshRegions. However, at the end of snappyHexMesh, all the patches are removed with the following warning: "Removing zero-sized patches". This is my snappyHexMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg" castellatedMesh true; snap true; addLayers false; geometry { solido_semplice_patch.stl { type triSurfaceMesh; name solidoSemplice; regions { solido{name contact_solido; type wall;} top{name topWall; type wall;} bottom{name bottomWall; type wall;} } } fluido_semplice_patch.stl { type triSurfaceMesh; name fluidoSemplice; regions { fluido{name contactFluido; type wall;} inlet{name entrata; type patch;} outlet{name uscita; type patch;} } } }; castellatedMeshControls { // Refinement Parameters maxLocalCells 10000000; maxGlobalCells 50000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 2; // Locale curvature and feature angle refinement resolveFeatureAngle 15; planarAngle 30; features ( ); refinementSurfaces { solidoSemplice { level (2 2); faceZone solidoSemplice; cellZone solidoSemplice; cellZoneInside insidePoint; insidePoint (0.0 0.006 0); } fluidoSemplice { level (2 2); faceZone fluidoSemplice; cellZone fluidoSemplice; cellZoneInside insidePoint; insidePoint (0.0 0.0 0.000); } } refinementRegions { } locationInMesh (0 0 0); allowFreeStandingZoneFaces true; /* faceZoneControls { solido_to_fluido { patchInfo { type patch; } faceType baffle; } fluido_to_solido { patchInfo { type patch; } faceType baffle; } } */ } snapControls { // Number of patch smoothing iterations before finding correspondence to surface nSmoothPatch 3; // Maximum relative distance for points to be attracted by surface. // True distance is this factor times local maximum edge length. //Note: changed(corrected) w.r.t 17x! (17x used 2* tolerance) tolerance 2.0; // Number of mesh displacement relaxation iterations. nSolveIter 20; // Maximum number of snapping relaxation iterations. // Should stop before upon reaching a correct mesh. // Increase this value to improve the quality of the body fitted mesh. nRelaxIter 20; // Feature snapping // Number of feature edge snapping iterations. // Leave out altogether to disable. // Increase this value to improve the quality of the edge features. nFeatureSnapIter 15; // Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; // Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; // Detect features between multiple surfaces // (only for explicitFeatureSnap, default = false) multiRegionFeatureSnap true; } addLayersControls { relativeSizes true; expansionRatio 1.2; finalLayerThickness 0.5; minThickness 1e-3; layers { } // Advanced settings nGrow 0; featureAngle 130; maxFaceThicknessRatio 0.5; nSmoothSurfaceNormals 1; nSmoothThickness 10; minMedianAxisAngle 90; maxThicknessToMedialRatio 0.3; nSmoothNormals 3; slipFeatureAngle 30; nRelaxIter 5; nBufferCellsNoExtrude 0; nLayerIter 50; nRelaxedIter 20; } meshQualityControls { maxNonOrtho 50; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1.00E-16; minTetQuality 1e-12; minArea -1; minTwist 0.05; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; minFlatness 0.5; nSmoothScale 4; errorReduction 0.75; } mergeTolerance 1e-6; // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 8-1c9b5879390b Exec : snappyHexMesh -parallel -noFunctionObjects -overwrite Date : Dec 23 2022 Time : 18:41:50 Host : "server1" PID : 7783 I/O : uncollated Case : /mnt/d/OpenFOAM/noTPMS nProcs : 6 Slaves : 5 ( "server1.7784" "server1.7785" "server1.7786" "server1.7787" "server1.7788" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 0.01 s Overall mesh bounding box : (-0.008 -0.008 -0.009) (0.008 0.008 0.009) Relative tolerance : 1e-06 Absolute matching distance : 2.891366459e-08 Reading refinement surfaces. Read refinement surfaces in = 0.02 s Reading refinement shells. Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Reading features. Read features in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 14656 Number of edges to retest : 14656 Number of intersected edges : 1704 Calculated surface intersections in = 0 s Initial mesh : cells:4608 faces:14656 points:5491 Cells per refinement level: 0 4608 Adding patches for surface regions ---------------------------------- Patch Type Region ----- ---- ------ solidoSemplice: 1 wall bottomWall 2 wall bottomWall_slave 3 wall contact_solido 4 wall contact_solido_slave 5 wall topWall 6 wall topWall_slave fluidoSemplice: 7 wall contactFluido 8 wall contactFluido_slave 9 wall entrata 10 wall entrata_slave 11 wall uscita 12 wall uscita_slave Added patches in = 0.02 s ... ... Removing zero-sized patches: bottomWall type wall at position 1 bottomWall_slave type wall at position 2 contact_solido type wall at position 3 contact_solido_slave type wall at position 4 topWall type wall at position 5 topWall_slave type wall at position 6 contactFluido type wall at position 7 contactFluido_slave type wall at position 8 entrata type wall at position 9 entrata_slave type wall at position 10 uscita type wall at position 11 uscita_slave type wall at position 12 Snapped mesh : cells:125960 faces:401284 points:149373 Cells per refinement level: 0 584 1 18880 2 106496 Writing mesh to time constant Wrote mesh in = 0.25 s. Mesh snapped in = 3.4 s. Checking final mesh ... Checking faces in error : non-orthogonality > 50 degrees : 0 faces with face pyramid volume < 1e-16 : 0 faces with face-decomposition tet quality < 1e-12 : 0 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.05 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.05 : 0 faces on cells with determinant < 0.001 : 0 Finished meshing without any errors Finished meshing in = 7.33 s. End Finalising parallel run I also attach pictures of the domain. How can I do to fix that issue? Thank in advance, Greetings, Eleonora |
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 05:56 |
[snappyHexMesh] Creating baffes with snappyHexMesh | BBack | OpenFOAM Meshing & Mesh Conversion | 0 | September 22, 2019 06:10 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 09:00 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 13:40 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
