[Technical] OpenFOAM v2112 SphereDrop revisition
Old   December 7, 2022, 06:36
Default OpenFOAM v2112 SphereDrop revisition
Kyle
wkholy is on a distinguished road
I tried to revise the tutorial sphereDrop case by removing the farfield and leave the moving part only. It will act as a piston but drop along the wall.
However, when I remove the farfield zone, there would not be a pair of cycleAMI b.c., but a patch-type innerAMI only. The innerAMI is assigned a patch type referred to the movingConeTopo in extend version, but the mesh near the innerAMI patch is deformed badly when the sphere is dropping further, not translated with the sphere as expected.
I tried the moveingCone case yet it is not supported by OF v2112. May I ask if there is a solution for such setting?
wkholy is offline   Reply With Quote
Old   December 7, 2022, 06:51
Yann
Yann will become famous soon enoughYann will become famous soon enough
I don't have a direct answer but there is a movingCone tutorial in v2112: $FOAM_TUTORIALS/incompressible/pimpleFoam/laminar/movingCone
Isn't it the one you are looking for?
Regards,
Yann
Yann is offline   Reply With Quote
Old   December 7, 2022, 10:52
Kyle
Hi, Yann, thanks for the response. The topology is unchanged in the tutorial of movingCone. What I would like to model is the cone attached on the top wall, which will change the topolgy whist the cone is moving.
In extend 1.6, it provides a case of movingConeTopo, which uses movingConeTopoFvMesh and layer addition/removal. I find this class is also included in of v2112, but fail to set up for the case.
Regards,
Yann
Old   December 7, 2022, 11:15
Kyle
Here is similar description with my problem.
https://scicomp.stackexchange.com/qu...of-variable-di
The solution seems yet unresolved.
Regards,
Yann
Old   August 29, 2023, 07:55
Michael Sukham
2538sukham is on a distinguished road
The pimpleFoam movingCone tutorial uses laplacian mesh motion. I am using the latest v2306 and by changing the dynamicMeshDict to address the movingConeTopoFvMesh inputs, the simulation runs. But then the velocity and pressure field is not satisfactory if compared to the one given in the tutorial. Are you looking only for the topoChange?
OpenFOAM v10 introduces a meshToMesh i think, which maps the solution to a predetermined mesh. I am also struggling with the velocity field after layer removal.
2538sukham is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
[OpenFOAM.org] implementation OpenFOAM v9 vs v2112 B6_lacen OpenFOAM Installation 0 February 22, 2022 11:28
OpenFOAM v2112 developers upgrade announcement opencfd OpenFOAM Announcements from ESI-OpenCFD 0 November 30, 2021 08:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
