October 24, 2022, 11:45 |
Average cell size
I have to do a grid convergence study and i need the average cell size (mesh obtained with snappyhexmesh), but i can't figure it out how to do it. Could someone help me? Thanks |
October 25, 2022, 02:28 |
M
Rep Power: 12 |
1) checkMesh can put out cellVolume field which you can use (-writeAllFields option)
2) Paraview has a filter called mesh quality. This allows you to extract all sorts of quality measures per cell. You can presribe it to put out the cell volume as a field, which you can either export and process somewhere else or make e.g. a histogram in Paraview itself. I remember with this approach, sometimes PV is not able to extract volume (or was it area?) correctly for all cell types, then the result may be off. |
May 13, 2024, 07:55 |
#3 | |
Mohd Shaeq
Rep Power: 3 |
= where is the average size of an element, is the volume of the mesh, and is the number of hexahedral elements of which the mesh is composed. The latter two can easily be found out using the checkMesh utility. The following link explains this procedure in detail:- https://www.sandia.gov/files/cubit/1...tem/set-up.htm |
average cell, mesh, openfoam2112 |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 07:21 |
Choice of cell size w.r.t size of the domain for meshing | mazhar16823 | Main CFD Forum | 1 | June 16, 2020 01:53 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Courant Number Cell Size | vitorgabriel | OpenFOAM Pre-Processing | 0 | June 3, 2016 10:41 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
