[Gmsh] Need help for creating a ellipsoid cavity inside a box in Gmsh
Old   October 18, 2022, 16:40
Default Need help for creating a ellipsoid cavity inside a box in Gmsh
J Powell
miraboreasu is on a distinguished road
Hello
Sorry I found here is the place for gmsh
I have a sphere inside a box with a radius equal to 0.05 and make a physical surface
SetFactory("OpenCASCADE");
Block(1) = {0, 0, 0, 5, 5, 5};
Sphere(2) = {2.5, 2.5, 2.5, 0.05};
BooleanDifference(3) = { Volume{1}; Delete; }{ Volume{2}; Delete; };
inner() = Surface In BoundingBox{2.449,2.449,2.449, 2.551, 2.551, 2.551};
Physical Volume("my volume") = {3};
Physical Surface("my inner surface") = inner();
Mesh.MeshSizeFromCurvature = 30;
Mesh.MeshSizeMax = 0.2;
Now I want to keep the same box, and the same center(2.5), but make this sphere into an ellipsoid, which has a larger c in the picture (looks like a shuttle), values of a, b, and c are in the picture. I also need a physical surface for this ellipsoid.
I searched online, but didn't find a good solution, can anyone help me? I prefer using OpenCASCADE, thanks!
miraboreasu is offline   Reply With Quote
Air speed estimate inside a box with one barrier cognitor Main CFD Forum 1 May 14, 2013 08:43
[GAMBIT] Mesh inside computer box r.sirait ANSYS Meshing & Geometry 4 June 13, 2012 02:50
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Radiative heat transfer with natural convection inside a square cavity msarkar OpenFOAM 1 January 11, 2010 23:21
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
