[Salome] errors using "ideasUnvToFoam" convert .unv files to openfoam format |
Rep Power: 0 ![]() |
The problem is when I converting the .unv file to generate meshs in openfoam , the following errors occur.
the .unv file is exported from salome in newest version(9.9.0) and operate with openfoam9 (not 10! which is newest one) --> FOAM Warning : From function void readSets(Foam::IFstream&, Foam:: DynamicList<Foam::word>&, Foam:: DynamicList<Foam::List<int> >&) in file ideasUnvToFoam.C at line 559 Reading "AirFoil.unv" at line 198878 When reading patches expect entity type code 8 Skipping group code -1 --> FOAM FATAL IO ERROR: Attempt to get back from bad stream file: IStringStream.sourceFile at line 0. From function bool Foam::Istream::getBack(Foam::token&) in file db/IOstreams/IOstreams/Istream.C at line 56. FOAM exiting Any suggestions please, my English is not very well, please forgive me ![]() Thanks everybody advanced! By the way , this is my first thread , tell me if I make anything wrong ![]() Last edited by zhihenghuang; October 6, 2022 at 10:26. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
how to convert .txt files to OpenFOAM format | boffin5 | OpenFOAM Running, Solving & CFD | 4 | July 28, 2021 14:16 |
[Technical] How to convert Corner-grid format to OpenFOAM mesh | ELwardi | OpenFOAM Meshing & Mesh Conversion | 0 | April 20, 2019 12:05 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
