[Other] Parametric study in openfoam
Old   September 23, 2022, 15:09
Unhappy Parametric study in openfoam
April1004 is on a distinguished road
I want to do a simulation to investigate the impact of the gap-width between foresail (jib) and mainsail of a sailing boat.
The simulations shall have those three parameters:
- Wind angle of attack
- Angle of the foresail
- Angle of the mainsail
I know, that I can adjust the wind angle by changing the OpenFOAM-files for the initial conditions. Creating a script for this is not a problem.
But for the foresail and mainsail angle, I think I have to create a specific model and mesh for each combination of parameters.
I tried to do this with BlockMesh, but I stopped doing this, because "inner walls" are not allowed in BlockMesh, which makes this very complicated and time-consuming.
I think what I am trying to do is called "parametric study". Is this correct?
Do you have suggestions on how to do this? I am also willing to read other literature, that you suggest.
I have an informatics degree, so doing some python- or UNIX scripting shouldn't be a problem.
Thank you very much in advance
April1004 is offline   Reply With Quote
Old   September 24, 2022, 02:52
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
There are many tutorials on how to do this.
https://github.com/nelinnemann/of-ca...latypus-2D-car
https://holzmann-cfd.com/community/t...tric-variation
Beware, this will take time and effort and only you can implement it.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
parametric geometry
ERCOFTAC centrifugal pump case study with OpenFOAM extend 3.2 saleriCAE OpenFOAM 0 March 8, 2017 06:16
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Parametric Study Murat FloEFD, FloWorks & FloTHERM 1 October 13, 2008 04:20
