[snappyHexMesh] Layer collapses on radius with quality option |
September 18, 2022, 11:29 |
Wolfram Schneider
Rep Power: 8 |
I am trying to mesh a pretty simple propeller. Here you can see the geometry already snapped. Screenshot 2022-09-18 155759.jpg Everything looks fine unless the layers. The layer creation always collapses when a reasonable value for "minTetQuality" in the meshQualityDict is applied. It collapses even for 1e-30 for example. All layers are created, when "minTetQuality" is set to "-1", but with this mesh "mapFields" and so on does not work and an error message like "no base point for face ..." occurs. Here you can see the collapsed layers: Screenshot 2022-09-18 155912.jpg I am playing for days now with all parameters before asking you for any advice. Here are my current sHM settings. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { AMI.stl { type triSurfaceMesh; name AMI; } regions.stl { type triSurfaceMesh; name regionss; regions { inlet { name inlet; } outlet { name outlet; } wall { name wall; } propeller_1 { name propeller_1; } propeller_2 { name propeller_2; } obstacle { name obstacle; } } } } // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 10000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 200000000; // The surface refinement loop might spend lots of iterations // refining just a few cells. This setting will cause refinement // to stop if <= minimumRefine are selected for refinement. Note: // it will at least do one iteration (unless the number of cells // to refine is 0) minRefinementCells 0; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 3; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "AMI.eMesh"; level 0; } { file "propeller_1.eMesh"; level 0; } { file "inlet.eMesh"; level 0; } { file "outlet.eMesh"; level 0; } { file "obstacle.eMesh"; level 0; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { /* part from Holzmann AMI { level (3 5); faceZone rotatingZone; cellZone rotatingZone; cellZoneInside inside; }*/ AMI { level (2 3); // How to handle faceZones // a. no faceZone. No keyword 'faceZone' or 'faceZoneNaming' // b. single user-specified faceZone: // faceZone myZone; // c. faceZones according to the surface/region: // faceZoneNaming region; // c. faceZones according to the surface/region faceZone AMI1; //name of the faceZone ... the name of the boundary is set under geometry above faceType baffle; cellZone cellMRFzone; cellZoneInside inside; } regionss { level (0 0); //patchInfo { type wall; } inGroups (regionss); // Override per-patch information regions //this is not the name of any own file. This "regions" is part of the synthax { inlet { level (1 2); patchInfo { type patch; } } outlet { level (1 2); patchInfo { type patch; } } wall { level (1 2); patchInfo { type wall; } } obstacle { level (3 3); patchInfo { type wall; } } propeller_1 { level (5 5); //(6 7) patchInfo { type wall; } } propeller_2 { level (5 5); //(6 7) patchInfo { type wall; } } } } } // Resolve sharp angles resolveFeatureAngle 5; //30 // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { //refinementBox //{ // mode inside; // levels ((1E15 4)); //} AMI { levels ((3 3)); mode inside; } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (1e-5 -1e-2 -0.025); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 5; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 3; //- Number of mesh displacement relaxation iterations. nSolveIter 100; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 20; //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Of limited use in this case since faceZone faces not handled. nFeatureSnapIter 30; //(5) implicitFeatureSnap false; explicitFeatureSnap true; //- Detect features between multiple surfaces // (only for explicitFeatureSnap, default = false) multiRegionFeatureSnap true; } // Settings for the layer addition. addLayersControls { relativeSizes false; // Per final patch (so not geometry!) the layer information layers { propeller_1 { nSurfaceLayers 10; thickness 0.0005; expansionRatio 1.2; } propeller_2 { nSurfaceLayers 10; thickness 0.0005; expansionRatio 1.2; } wall { nSurfaceLayers 10; thickness 0.003; expansionRatio 1.2; } obstacle { nSurfaceLayers 10; thickness 0.003; expansionRatio 1.2; } } thickness 0.001; // Expansion factor for layer mesh expansionRatio 1.2; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. //finalLayerThickness 0.5; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.0000001; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 180; //slipFeatureAngle 10; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 10; //5 //nRelaxedIter 2; //gab es vorher nicht // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 20; //10 // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 5; // Smooth layer thickness over surface patches nSmoothThickness 2; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 1; //0 // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 1.7.x! 90 degrees corresponds to 130 // in 1.7.x. minMedialAxisAngle 80; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 100; //nSmoothDisplacement 10; //gab es vorher nicht // Max number of iterations after which relaxed meshQuality controls // get used. Up to nRelaxIter it uses the settings in meshQualityControls, // after nRelaxIter it uses the values in meshQualityControls::relaxed. nRelaxedIter 20; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" relaxed { maxNonOrtho 180; minTetQuality -1; } // Advanced //- Number of error distribution iterations nSmoothScale 4; //- Amount to scale back displacement at error points errorReduction 0.75; } // Advanced // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-8; // ************************************************************************* // |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
