[mesh manipulation] Advanced field mapping (Coordinate transformation) |
Jeffrey Johnston
Rep Power: 5 ![]() |
Hello folks,
I am generating initial turbulent conditions using a large mesh. I then need to map a small region of this unto a new mesh for a wind turbine problem. The problem is that the meshes do not share an origin or coordinate orientation. I've attached a diagram illustrating the source and target meshes. Can I use mapFields to do this, or are there other utilities? |
mapfields, meshing, openfoam |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 18:44 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
cartesian to general coordinate transformation | Keith | Main CFD Forum | 4 | February 16, 2004 19:40 |
mapping of a flow field | Uli | Main CFD Forum | 2 | November 1, 2001 12:12 |
