[snappyHexMesh] Refinement too far from surface
Old   August 24, 2022, 12:57
Exclamation Refinement too far from surface
Anon
CfdUser5855 is on a distinguished road
Hi all,
This should be an easy one, but I can't seem to fix it.
My mesh is created no problem, passes mesh checks etc. But as seen in the attached photo, it refines far too high up the domain.
I've tried changing refinement region, changing to mode distance, changing the levels etc but it always creates the same mesh.
Can anyone please advise how I can lower where the refinement starts? The domain is 250 m tall, and I ideally want the nearest 50 m to the surface refined and the rest is alright.
Below is my snappyhexmesh:
castellatedMesh true;
snap true;
addLayers true;
geometry
refinementBox
type searchableBox;
min (1635 518305 0);
max (2700 519270 200);
DuneField
type triSurfaceMesh;
file "DuneField.stl";
castellatedMeshControls
maxLocalCells 2000000000;
maxGlobalCells 2000000000;
minRefinementCells 1;
maxLoadUnbalance 0.10;
nCellsBetweenLevels 1;
refinementSurfaces
DuneField
// Surface-wise min and max refinement level
level (0 0);
// Optional region-wise level specification
regions
refinementBox
level (5 5);
resolveFeatureAngle 5;
refinementRegions
refinementBox
mode inside;
levels ((5 5)); //4 4 or 6 6
locationInMesh (2000 518500 250);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 3;
tolerance 2.0;
nSolveIter 30;
nRelaxIter 5;
addLayersControls
relativeSizes true;
layers
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.25;
nGrow 0;
featureAngle 60;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 90;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
meshQualityControls
maxNonOrtho 45;
maxBoundarySkewness 10;
maxInternalSkewness 2;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.05;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
relaxed
maxNonOrtho 45;
mergeTolerance 1e-5;
Thanks
CfdUser5855 is offline   Reply With Quote
refinement, snappy hex mesh
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
problem with parallel calculations OF8 mpirun otaolafr OpenFOAM Programming & Development 0 January 5, 2021 08:33
[snappyHexMesh] Surface triangulation using snappyHexMesh shaileshbg OpenFOAM Meshing & Mesh Conversion 4 October 17, 2019 05:42
[snappyHexMesh] Bad meshing result on corrugated metal sheet UebertreibeR OpenFOAM Meshing & Mesh Conversion 1 August 19, 2016 05:55
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
