July 29, 2022, 06:27 |
[blockMesh]: problem create a wedge geometry
Craig Thomas
Rep Power: 6 |
Hi Philip,
I'm sorry for hijacking this post and I know this is in the completely wrong thread to ask this question, but I'm trying to create a wedge geometry as we had previously discussed in the thread. I am trying to follow the guidance from the openFoam user guide: https://www.openfoam.com/documentati...4.2-boundaries https://www.openfoam.com/documentati...x13-480004.3.3 I have managed to create the geometry with blockMesh; however, when I run checkMesh I receive the following output: [mn14cat@login2.arc4 nonLinBlock]$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : checkMesh -allGeometry -allTopology Date : Jul 29 2022 Time : 11:18:48 Host : login2.arc4.leeds.ac.uk PID : 241768 CtrlDict : "/home/home01/mn14cat/foam/mn14cat-4.0/run/usr_cases/solidMechanics/nonLinBlock/system/controlDict" Case : /home/home01/mn14cat/foam/mn14cat-4.0/run/usr_cases/solidMechanics/nonLinBlock nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats all points: 6 live points: 6 all faces: 5 live faces: 5 internal faces: 0 cells: 1 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 1 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. <<Writing 1 cells with with single non-boundary face to set oneInternalFaceCells Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Area [m^2] Surface topology Bounding box topLoading 1 3 0.05 ok (non-closed singly connected) (0 1 -0.05) (1 1 0.05) axis 0 0 0 ok (empty) (0 0 0) (0 0 0) freeSurface 1 4 0.1 ok (non-closed singly connected) (1 0 -0.05) (1 1 0.05) fixedBottom 1 3 0.05 ok (non-closed singly connected) (0 0 -0.05) (1 0 0.05) back 1 4 1.00125 ok (non-closed singly connected) (0 0 -0.05) (1 1 0) front 1 4 1.00125 ok (non-closed singly connected) (0 0 0) (1 1 0.05) Checking geometry... This is a 3-D mesh Overall domain bounding box (0 0 -0.05) (1 1 0.05) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 2 ***Number of edges not aligned with or perpendicular to non-empty directions: 4 Writing 6 points on non-aligned edges to set nonAlignedEdges Boundary openness (0 0 0) Threshold = 1e-06 OK. Max cell openness = 0 OK. Max aspect ratio = 20 OK. Minumum face area = 0.05. Maximum face area = 1.00125. Face area magnitudes OK. Min volume = 0.05. Max volume = 0.05. Total volume = 0.05. Cell volumes OK. Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.330008 OK. Min/max edge length = 0.1 1.00125 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1 All face flatness OK. ***Cells with small determinant found, number of cells: 1 Writing 1 under-determined cells to set underdeterminedCells Failed 2 mesh checks. End I have tried to read up on the cause of the non-aligned edges on a couple of threads on the forum https://www.cfd-online.com/Forums/op...ion-print.html Number of edges not aligned with or perpendicular to non-empty directions but I still don't understand the cause of the problem. This is my blockMeshDict file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant/polyMesh"; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (1 0 -0.05) //1 (1 1 -0.05) //2 (0 1 0) //3 (1 0 0.05) //4 (1 1 0.05) //5 // (1 1 0.05) //6 // (0 1 0.05) //7 ); blocks ( hex ( 0 3 3 0 1 2 5 4 ) (10 10 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch topLoading ( (2 3 3 5) ) symmetry axis ( (3 0 0 3) ) patch freeSurface ( (1 2 5 4) ) patch fixedBottom ( (0 1 4 0) ) wedge back ( (0 1 2 3) ) wedge front ( (3 5 4 0) ) ); mergePatchPairs ( ); // ************************************************** *********************** // I would really appreciate any guidance on the root of this problem. p.s. I also tried to visualise the problem in paraview but that also didnt help at all. Many Thanks in advance Craig |
August 3, 2022, 10:34 |
Philip Cardiff
Rep Power: 34 |
Hi Craig,
Have a look at the following axisymmetric blockMeshDict example from solids4foam: https://bitbucket.org/philip_cardiff...uniaxialRod.m4 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
[CAD formats] Unable to import STL properly to create final geometry | miguel.delasheras | OpenFOAM Meshing & Mesh Conversion | 2 | January 27, 2019 06:27 |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 04:55 |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[DesignModeler] problem with import geometry from catia | pavilion | ANSYS Meshing & Geometry | 1 | November 23, 2012 10:45 |
