August 3, 2022, 09:55 |
Skew Faces in Mesh
Anon
Rep Power: 6 |
Hi All,
I have an issue with 2 skew faces I cannot remove. I've made the mesh as close to a 1:1 ratio as I can, and tried modifying the boundaryskewness and internal skewness but I am left with 2 skew faces regardless of what I try. I have attached 3 images of the domain, showing the skew faces as a glyph, then what the surface mesh is like. I previously have had no issues with skew faces, but cannot remove these. If anyone can help, that would be greatly appreciated. The Blockmesh is as follows: convertToMeters 1; vertices ( (60 -2451510 -1765) (1880 -2451510 -1765) (1880 -2449793 -1765) (60 -2449793 -1765) (60 -2451510 -1400) (1880 -2451510 -1400) (1880 -2449793 -1400) (60 -2449793 -1400) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 9 2) simpleGrading (1 1 1) //was13 12 2 ); edges ( ); boundary ( outlet { type patch; faces ( (0 4 7 3) (1 5 4 0) ); } inlet { type patch; faces ( (2 6 5 1) (3 7 6 2) ); } Mesa { type wall; faces ( (0 3 2 1) ); } top { type patch; faces ( (4 5 6 7) ); } ); mergePatchPairs ( ); snappyhexMesh is as follows: castellatedMesh true; snap true; addLayers true; geometry { refinementBox { type searchableBox; min (0 -2451600 -2000); max (1470 -2440000 -1000); } Mesa { type triSurfaceMesh; file "NewMesa_STL.stl"; } }; castellatedMeshControls { maxLocalCells 100000000; maxGlobalCells 200000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 8; features ( { file "NewMesa_STL.eMesh"; level 2; } ); refinementSurfaces { Mesa { // Surface-wise min and max refinement level level (5 5); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ refinementRegions { /* refinementBox { levels ((0 1)); mode inside; } */ } locationInMesh (1000 -2450000 -1600); allowFreeStandingZoneFaces true; } snapControls { nSmoothPatch 5; tolerance 1.0; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 10; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap false; } addLayersControls { { /* Mesa { nSurfaceLayers 3; } */ } expansionRatio 1.1; finalLayerThickness 0.2; minThickness 0.1; nGrow 0; featureAngle 60; slipFeatureAngle 30; nRelaxIter 3; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } meshQualityControls { maxNonOrtho 45; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetQuality 1e-30; minArea -1; minTwist 0.01; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } writeFlags ( scalarLevels layerSets layerFields ); mergeTolerance 1e-6; |
mesh, skew faces, snappyhexmesh |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
