[snappyHexMesh] Mesh very small geometry
Old   July 4, 2022, 01:21
Default Mesh very small geometry
JonathanB
jonathanb is on a distinguished road
I am trying to simulate an air knife. My issue is that the very small features are missed from Snappyhexmesh. I am simply using the FreeCAD CfdOF plugin and am looking for assistance in the SHM flags to make this work.
That is, greatly simplified, a 30mm bore x 100mm long. One end is the inlet at 500kPa air. Along the full length of the bore is a thin protrusion 50um wide and 5mm long. The end of the protrusion 50um x 100mm is open to atmosphere. All other surfaces are no-slip walls.
I have tried to add a mesh refinement to the area in FreeCAD and decrease the base element size and the edge refinement, nothing works. Too small and the meshing crashes. I am yet to mesh the outlet successfully.
Please see the following
https://postimg.cc/JGN8MPz7
https://postimg.cc/GBZgBnXW
jonathanb is offline   Reply With Quote
Old   July 5, 2022, 17:24
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Snappy really is not the right tool for a mesh of this type.
You will be better off using blockMesh, but I would recommend Salome.
Attached are two solutions for making the mesh.
You can import the pipeSlit.py (remove the .txt) in Salome.
You can compute the mesh and extrude it.
Salome will automatically create boundary names for you.
Edge groups will become facegroups when extruded.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
small face, small mesh, snappyhexmesh
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] Complex Geometry for Hex Mesh smoerebroet ANSYS Meshing & Geometry 0 January 9, 2015 16:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
