[Other] dynamicMeshDict dynamicRefineFvMesh with rhoCentralFoam
Old   June 30, 2022, 05:38
Default dynamicMeshDict dynamicRefineFvMesh with rhoCentralFoam
Vinzenz Götz
Vinzmann is on a distinguished road
so I am using OF8 and I want to adaptively refine my mesh in areas where the magnitude of grad(p) is high. rhoCentralFoam does only take volScalarFields though. Since this is the case, how can I get this to work? Any help would be greatly appreciated. The output for rhoCentralFoam looks like this:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0]
    request for volScalarField mag(Grad(p)) from objectRegistry region0 failed
    available objects of type volScalarField are
20
thermo:mu
thermo:psi
rhoE_0
nut
yWall
rho
k
thermo:psi_0
e_0
alphat
rho_0
p
T
rhoE
k_0
p_0
e
omega
omega_0
thermo:alpha
My dynamicMeshDict looks like this:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      dynamicMeshDict;
dynamicFvMesh		dynamicRefineFvMesh;
dynamicRefineFvMeshCoeffs
	refineInterval	5;
	field			mag(Grad(p));
	lowerRefineLevel	3e5;
	upperRefineLevel	4e5;
	unrefineLevel		1e5;
	nBufferLayers		5;
	maxRefinement		3;
	maxCells			1000000;
	correctFluxes
		(phi U)
	dumpLevel			true;
Vinzmann is offline   Reply With Quote
Old   July 1, 2022, 04:04
Default Solution
Vinzenz Götz
So I've found a solution to this problem. Create two new functions in the controlDict. First a function giving grad(p) (you can look this up in the documentation for functionObjects) then another function to create mag of grad(p). This new field can be set in the dynamicMeshDict as the fild to work on.
amr, dynamic meshing, dynamicmeshdict
DynamicRefineFvMesh & Supersonic Erosion siefer92 OpenFOAM Programming & Development 1 February 4, 2021 18:00
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 14:17
Does dynamicRefineFvMesh work with unstructured tetra meshes? giovanni.medici OpenFOAM Running, Solving & CFD 2 August 23, 2017 03:35
I can't understand the moving function of "libfvMotionSolver.so" in dynamicMeshDict Jung hoo OpenFOAM Programming & Development 0 July 13, 2016 04:36
DynamicMeshDict dynamicRefineFvMesh in 2D lukasfischer OpenFOAM Running, Solving & CFD 4 November 10, 2014 08:19
