[snappyHexMesh] Unable to add Layer properly because of snap quality
Old   June 27, 2022, 11:39
Default Unable to add Layer properly because of snap quality
Giorgio Eid is on a distinguished road
Hello, I am working on a simplified model of a bluff body, it was designed using CatiaV5 and was then converted to an STL file using Salome 9.8.0. After running blockMesh and surfaceFeatures, I have a problem with the snappyHexMesh.
See the attached picture for the current result; the add layer function is not working well on the front face. I suspect that it might be related to the snapping part which give a far from smooth front face. I have tried to modify every parameter of the snappyHexMeshDict, improving the stl resolution, changing refinement levels and I still can't solve the issue.
I would appreciate any kind of help or advice, I need to improve the quality of this mesh.
PS: also find attached my snappyHexMeshDict wish gave me the best final mesh, although it still has a lot of room for improvement.
Giorgio Eid is offline   Reply With Quote
addlayers, snap controls, snappyhesmesh
[snappyHexMesh] SHM Bad quality snapping/terracing ryan55510 OpenFOAM Meshing & Mesh Conversion 0 April 20, 2022 21:20
[snappyHexMesh] Holes in internal mesh when adding boundary layer snappyHex otaolafr OpenFOAM Meshing & Mesh Conversion 3 February 8, 2021 09:19
[snappyHexMesh] SHM doesn't snap the boundary between two surfaces on same plane decanter OpenFOAM Meshing & Mesh Conversion 4 November 17, 2020 16:32
How to add three layer of different coating in ansys geometry Ajmit ANSYS 1 November 16, 2020 04:14
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
