[mesh manipulation] Splitting meshes generated from snappyhexmesh
Old   June 17, 2022, 07:31
Default Splitting meshes generated from snappyhexmesh
Nico
Hr_kules is on a distinguished road
i am wondering wether the splitmeshregions command is sensitive to the stl used to create the mesh in snappyhexmesh being closed or not.
I have a case that is basically the shell and tube heat exchanger tutorial with different geometry files. I have checked both the stls from the tutorial with surfaceCheck and the only difference in the entire case is that my code generated stls are not closed.
Additional info: the stls used for the check are the acutal zones say "tube.stl" as well as the single surface "tube_to_solid" merged into one file.
If so that would solve a problem, however i would love to hear some experiences from you guys, maybe someone had a similar problem in the past?
Hr_kules is offline   Reply With Quote
Splitting of generated mesh jenna Mesh Generation & Pre-Processing 0 November 7, 2016 09:45
How can I put the data of adpated meshes on the original unadapted meshes? xh110120 FLUENT 2 March 11, 2016 03:00
[ANSYS Meshing] icemcfd meshes generated mxr198708 ANSYS Meshing & Geometry 0 February 18, 2014 19:10
[snappyHexMesh] Surface Meshes Merged in SnappyHexMesh (Pictures Inlcuded) sda OpenFOAM Meshing & Mesh Conversion 3 December 3, 2012 14:01
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 20:51
