[mesh manipulation] Using stl to create CellZone
Old   June 16, 2022, 06:35
Default Using stl to create CellZone
Nico
Hr_kules is on a distinguished road
Hey everyone,
i have troubles with splitting my mesh for a multiregion mesh simulation. I created the mesh with snappyhexmesh without any problems, however after i split the mesh, the boundaries are all over the place and don't match any region i want.
I use the standard command splitMeshRegions -cellZones -defaultRegionName plate -overwrite
Now i want to try to use the flag cellZonesOnly as the error was resolved when i used an imported mesh from ansys. Since the geometry overlaps at certain points i want to use the stls to encapsulate any cells that reside within that surface of the stl. I am however quite uncertain on how to achieve this with toposet.
Can somebody help?
Hr_kules is offline   Reply With Quote
[mesh manipulation] TopoSet cellset is not deleting from stl cellZone sunagra27 OpenFOAM Meshing & Mesh Conversion 0 March 9, 2021 02:50
[snappyHexMesh] SHM doesn't create cellZones for one region Eko OpenFOAM Meshing & Mesh Conversion 10 January 24, 2018 03:03
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh Irish09 OpenFOAM Meshing & Mesh Conversion 9 April 7, 2012 09:50
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
