[blockMesh] Tilted wedge possibilities?
Old   June 14, 2022, 11:45
Default Tilted wedge possibilities?
Chris van Dijk
chrisvandijk is on a distinguished road
Dear all,
For my Master Thesis I am modelling the melting of a certain phase change material (PCM) using an inhouse Univerisity code. I am going to use a cylindrical geometry at different inclination angles.
If the cylinder is upright (i.e. the disc-shaped surfaces of the cylinder are normal to the z direction) the situation is axisymmetric so I can use the wedge type in blockMesh. However, I also want to investigate the effect of inclination angle on the melting. This can be done easiest if I change the orientation of the gravity (e.g. if the cylinder is tilted 45 degrees the gravity now works in the (y-z)/sqrt(2) direction instead of the -z direction). This is important as natural convection, and therefore the rate of melting and the shape of the melting front, is dependent on the angle. However, because there is no circular axisymmetry anymore, I assume I cannot naïvely use the wedge type anymore.
Is there some way how I can use the wedge type (or something similar) for an inclined cylinder? If it's not possible I can always use a 3D model for a half cylinder (as there is one symmetry axis left), but of course that will be much more computationally expensive than a 2D model.
I have mostly worked with blockMesh for my meshes but I would not mind using another way of meshing if necessary. I am using OpenFOAM 8 on Ubuntu 20.04.
Thank you a lot in advance!
chrisvandijk is offline   Reply With Quote
axisymmetry, inclination, tilt, wedge
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
chtMultiRegionFoam: two fluid regions separated by a thin, conducting wall JayDeeUU OpenFOAM Pre-Processing 16 July 22, 2021 22:17
[blockMesh] Problems in creating a wedge type mesh Joscha OpenFOAM Meshing & Mesh Conversion 28 August 3, 2019 08:59
Axisymmetric Whirl BCs; Wedge or Cyclic? c_dowd OpenFOAM Pre-Processing 4 December 5, 2012 11:38
Wall boundary is ignored when using wedge Wedge OpenFOAM 1 February 7, 2011 07:20
