[blockMesh] Define blockMeshDict dynamically using c++ code |
Miguel Hernandez
Rep Power: 5 ![]() |
Hi everyone,
I am wandering if is possible to create a dynamic blockMeshDict file using c++ CODE. I know that is possible to use code #{ //c++ instructions... #}; but, what I'd like to know is if is possible to create a certain number of blocks using a for loop. To be precise, I would like to create a mesh of a stair, using a user defined variable (e.g. an integer variable) that represents the number of steps. Using this variable (or more than one variable) I would like to create a certain number of blocks equal to the defined variable. Does anyone know how to implement a code like that? How can I implement a for loop inside blocks ( ); Thanks in advance. Miguel |
blockmesh dict, c++ geometry |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 10:19 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
