[blockMesh] Mesh refinement and geometry of a Cube
Old   May 29, 2022, 09:08
Default Mesh refinement and geometry of a Cube
Thiago800 is on a distinguished road
Hello, I want to refine the mesh of a cube with edge length of 108mm. I am simulating a spray which sprays the fuel from the top to the bottom. I want to refine the mesh on the top where the fuel is injected to the cube. Further down and around the spray, the mesh should be coarser (green block). I want to divide the cube in 9 blocks, as you can see on the attached picture (and inject the fuel unlike on the picture, from the top to the bottom along y axis). The mesh in the middle block should be refined (red block).
I attached the paraview picture to show you from where the injection should begin.
Is it possible to do that by only adjusting simpleGrading or multiGrading? If so, how do I adjust it to achieve this division and refined mesh? I tried it many times, but I don't get it how I want to.
Thiago800 is offline   Reply With Quote
Old   July 5, 2024, 07:03
Default [blockMesh] Mesh refinement and geometry of a Cube
Srinivas
sri_0548 is on a distinguished road
Hello Tiago,
Did you solve this problem?
I'm also trying to refine the mesh in local regions using blockMesh. My geometry is a simple 2D rectangle. Could you please help me to refine the mesh?
sri_0548 is offline   Reply With Quote
Old   July 8, 2024, 06:27
Clap_7 is on a distinguished road
Originally Posted by sri_0548 View Post
Hello Tiago,
There are different options, like adjusting your BlockMesh or using RefineMesh. To be able to help you, more information and a simple picture of your wanted grid would be helpful.
Clap_7 is offline   Reply With Quote
mesh refinement study, spray injection
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
