[Salome] Meshing cylinder in salome
Old   May 23, 2022, 14:54
Default Meshing cylinder in salome
tRock is on a distinguished road
Hello to all,
I would like to make a cylinder with a square on top. Image bellow.
https://i.ibb.co/7GTcC5q/a.png
Is there any way to control the amount of elements across the thickness of the cylinder and the cube?
The approach is to create a plane to separate the objects. Now I need a way to control the amount of elements across the thickness.
Has anyone faced a similar issue? I could get the 10 elements across the thickness by setting the maximum size to a 1/10 of the thickness value but this will result in a huge mesh...
Best Regards
tRock is offline   Reply With Quote
Old   May 25, 2022, 08:08
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
See the attached Salome dump.
See if you can work through what it does.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
[ICEM] Meshing of a cylinder containing a small hole on one face Giova82 ANSYS Meshing & Geometry 1 August 12, 2015 07:49
Cylinder Intake Meshing dbagtbag CFX 11 July 30, 2015 08:59
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder nammari OpenFOAM Meshing & Mesh Conversion 5 March 11, 2011 20:49
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
