[blockMesh] inconsistent point locations between block pair
Old   May 21, 2022, 16:55
Red face inconsistent point locations between block pair
nopes
MaVV is on a distinguished road
Hi all,
If I try to make a mesh from the blockMeshDict below, it throws the error "inconsistent point locations between block pair 1 and 2 probably due to inconsistent grading". Anyone who knows where the mistake could be?
convertToMeters 1;
vertices
(0 0 0) //0
(507 0 0) //1
(507 5.233 0) //2
(0 5.233 0) //3
(517 0 0) //4
(518.85 1.85 0) //5
(520.7 3.7 0) //6
(520.7 5.233 0) //7
(565 5.233 0) //8
(565 3.7 0) //9
(566.85 1.85 0) //10
(568.7 0 0) //11
(578.7 0 0) //12
(1085.7 0 0) //13
(1085.7 5.233 0) //14
(578.7 5.233 0) //15
(0 0 1) //16
(507 0 1) //17
(507 5.233 1) //18
(0 5.233 1) //19
(517 0 1) //20
(518.85 1.85 1) //21
(520.7 3.7 1) //22
(520.7 5.233 1) //23
(565 5.233 1) //24
(565 3.7 1) //25
(566.85 1.85 1) //26
(568.7 0 1) //27
(578.7 0 1) //28
(1085.7 0 1) //29
(1085.7 5.233 1) //30
(578.7 5.233 1) //31
blocks
hex (0 1 2 3 16 17 18 19) (10 10 1 ) simpleGrading (1 1 1) //0
hex (1 4 5 2 17 20 21 18) (10 10 1) simpleGrading (1 1 1) //1
hex (2 5 6 7 18 21 22 23) (10 3 1) simpleGrading (1 1 1) //2
hex (6 9 8 7 22 25 24 23) (10 3 1) simpleGrading (1 1 1) //3
hex (9 10 15 8 25 26 31 24) (10 3 1) simpleGrading (1 1 1) //4
hex (10 11 12 15 26 27 28 31) (10 10 1) simpleGrading (1 1 1) //5
hex (12 13 14 15 28 29 30 31) (10 10 1) simpleGrading (1 1 1) //6
edges
arc 4 5 (517.925 0.925 0)
arc 20 21 (517.925 0.925 1)
arc 5 6 (519.775 2.775 0)
arc 21 22 (519.775 2.775 1)
arc 9 10 (565.925 2.775 0)
arc 25 26 (565.925 2.775 1)
arc 10 11 (567.775 0.925 0)
arc 26 27 (567.775 0.925 1)
boundary
inlet
type patch;
faces
(0 3 19 16)
outlet
type patch;
faces
(13 14 29 30)
top
type wall;
faces
(3 2 18 19)
(2 7 23 18)
(7 8 24 23)
(8 15 31 24)
(15 14 30 31)
bottom
type symmetryPlane;
faces
(0 1 17 16)
(1 4 20 17)
(11 12 28 27)
(12 13 29 28)
cylinder
type wall;
faces
(4 5 21 20)
(5 6 22 21)
(6 9 25 22)
(9 10 26 25)
(10 11 27 26)
sides
type empty;
faces
(0 1 2 3)
(16 17 18 19)
(1 4 5 2)
(17 20 21 18)
(5 6 7 2)
(21 22 23 18)
(6 9 8 7)
(22 25 24 23)
(9 10 15 8)
(25 26 31 24)
(11 12 15 10)
(27 28 31 26)
(12 13 14 15)
(28 29 30 31)
mergePatchPairs
Many thanks in advance
MaVV is offline   Reply With Quote
Old   May 22, 2022, 05:41
Talking Solution
nopes
I found the solution, OpenFOAM choked on the size of the domain, it worked when moving everything 517m to the left. New origin is point 4. There were also mistakes in the locations of the arcs. New working code is:
convertToMeters 1;
vertices
(-517 0 0) //0
(-10 0 0) //1
(-10 5.233 0) //2
(-517 5.233 0) //3
(0 0 0) //4
(1.0837 2.6163 0) //5
(3.7 3.7 0) //6
(3.7 5.233 0) //7
(48 5.233 0) //8
(48 3.7 0) //9
(50.6163 2.6163 0 ) //10
(51.7 0 0) //11
(61.7 0 0) //12
(568.7 0 0) //13
(568.7 5.233 0) //14
(61.7 5.233 0) //15
(-517 0 1) //16
(-10 0 1) //17
(-10 5.233 1) //18
(-517 5.233 1) //19
(0 0 1) //20
(1.0837 2.6163 1) //21
(3.7 3.7 1) //22
(3.7 5.233 1) //23
(48 5.233 1) //24
(48 3.7 1) //25
(50.6163 2.6163 1) //26
(51.7 0 1) //27
(61.7 0 1) //28
(568.7 0 1) //29
(568.7 5.233 1) //30
(61.7 5.233 1) //31
blocks
hex (0 1 2 3 16 17 18 19) (10 10 1) simpleGrading (1 1 1) //0
hex (2 5 6 7 18 21 22 23) (10 10 1) simpleGrading (1 1 1) //2
hex (6 9 8 7 22 25 24 23) (10 10 1) simpleGrading (1 1 1) //3
hex (9 10 15 8 25 26 31 24) (10 10 1) simpleGrading (1 1 1) //4
edges
arc 4 5 (0.282 1.416 0)
arc 20 21 (0.282 1.416 1)
arc 5 6 (2.284 3.418 0)
arc 21 22 (2.284 3.418 1)
arc 9 10 (49.416 3.418 0)
arc 25 26 (49.416 3.418 1)
arc 10 11 (51.418 1.416 0)
arc 26 27 (51.418 1.416 1)
boundary
inlet
type patch;
faces
(0 3 19 16)
outlet
type patch;
faces
(13 14 29 30)
top
type wall;
faces
(3 2 18 19)
(2 7 23 18)
(7 8 24 23)
(8 15 31 24)
(15 14 30 31)
bottom
type symmetryPlane;
faces
(0 1 17 16)
(1 4 20 17)
(11 12 28 27)
(12 13 29 28)
cylinder
type wall;
faces
(4 5 21 20)
(5 6 22 21)
(6 9 25 22)
(9 10 26 25)
(10 11 27 26)
sides
type empty;
faces
(0 1 2 3)
(16 17 18 19)
(1 4 5 2)
(17 20 21 18)
(5 6 7 2)
(21 22 23 18)
(6 9 8 7)
(22 25 24 23)
(9 10 15 8)
(25 26 31 24)
(11 12 15 10)
(27 28 31 26)
(12 13 14 15)
(28 29 30 31)
mergePatchPairs
block pair inconsistent, blockmesh, grading, meshing, openfoam
[blockMesh] Specifying a point which is not a vertex of a block sahmed OpenFOAM Meshing & Mesh Conversion 2 June 27, 2016 11:54
[blockMesh] Inconsistent number of faces between block pair 0 and 1 pupo OpenFOAM Meshing & Mesh Conversion 2 June 25, 2016 09:48
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
