[snappyHexMesh] OF SHM surfaceMeshExtract leads to non manifold stl |
May 5, 2022, 10:05 |
Rep Power: 5 |
I am using OpenFOAM v2112. I would like to extract a stl from a surface patch nicely meshed with snappyHexMesh. So I use the 'surfaceMeshExtract' (previously 'surfaceMeshTriangulate') utility (see here) However, despite the surface could be very well refined, it's ended systematically as made of multiple manifolds. How to constraint this to get a single manifold surface ? Many thanks in advance for any help. |
surfacemeshextract |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 07:01 |
[CAD formats] Degenerate triangles in STL for use in sHM | Dreoasteh | OpenFOAM Meshing & Mesh Conversion | 1 | September 27, 2017 11:17 |
[snappyHexMesh] Checkinf if SHM stl files are watertight | fracasce | OpenFOAM Meshing & Mesh Conversion | 2 | April 25, 2017 07:50 |
[snappyHexMesh] SHM does not follow STL geometry well | Illmatic | OpenFOAM Meshing & Mesh Conversion | 7 | July 23, 2016 12:07 |
[snappyHexMesh] sHM with cyclic patch on stl geometry | johannesk | OpenFOAM Meshing & Mesh Conversion | 2 | August 21, 2009 10:08 |
