[mesh manipulation] On spliting multi region meshes
Old   April 27, 2022, 08:50
Default On spliting multi region meshes
Nico
Hr_kules is on a distinguished road
Hey, since my rather humble beginings with openfoam i am stuck with a certain problem regarding the spliting of multi region meshes. I am using OpenFoam Version 9.
To finally resolve this as this will be somewhat fundamental to my phd i would like to discuss my error.
I have a boiled down case of a single plate with a chevron corrugation, for simplicity its a single quick and dirty done corrugation. I had this test case in ansys fluent and exported the stls to openfoam to use them in snappyhexmesh. The complete case is attached with an allrun script and a log from my previous run.
My main concern is the spliting of the mesh as the boundaries don't match up. If i run the case and examine the boundary files i have for the fluidregion the correct boundaries and the mesh is mediocore but resembles what i had in mind. (See attached image) However i can't open the mesh for the other region because the console states that the boundaries don't match up.
A closer look reveals that one of the interfaces is found in both boundary definitions.
fluid:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/fluidcold/polyMesh";
    object      boundary;
4
    inletcold
        type            patch;
        nFaces          2675;
        startFace       563642;
    outletcold
        type            patch;
        nFaces          2672;
        startFace       566317;
    wallfluidcold
        type            wall;
        inGroups        List<word> 1(wall);
        nFaces          36996;
        startFace       568989;
    fluidcold_to_solid
        type            mappedWall;
        inGroups        List<word>
3
wall
mappedPatch
baffles1
        nFaces          33762;
        startFace       605985;
        sampleMode      nearestPatchFace;
        sampleRegion    solid;
        samplePatch     solid_to_fluidcold;
solid
     \\/     M anipulation  |
FoamFile
    format      ascii;
    location    "constant/solid/polyMesh";
    object      boundary;
3
    wallsolid
        type            wall;
        nFaces          34685;
        startFace       292030;
    fluidcold_to_solid
        type            mappedWall;
        inGroups        List<word>
3
wall
mappedPatch
baffles1
        nFaces          1;
        startFace       326715;
        sampleRegion    solid;
    solid_to_fluidcold
        type            mappedWall;
        inGroups        List<word>
3
wall
mappedPatch
baffles1
        nFaces          33760;
        startFace       326716;
        sampleRegion    fluidcold;
        samplePatch     fluidcold_to_solid;
examining the log, if found a few entries i find highly intriguing, since snappyHexMesh states that:
Finished meshing without any errors
Finished meshing in = 94.08 s.
i found for the creation of the baffles:
Reading "createBafflesDict"
Created zone baffles1 at index 1 with 33763 faces
--> FOAM Warning :
    From function void createFaces(bool, const Foam::fvMesh&, const Foam::faceZone&, const labelList&, const labelList&, Foam::polyTopoChange&, Foam::PackedBoolList&, Foam::label&)
    in file createBaffles.C at line 395
    Found boundary face (in patch wallfluidcold) in faceZone baffles1 to convert to baffle patches fluidcold_to_solid/solid_to_fluidcold
    Set internalFacesOnly to true in the createBaffles control dictionary if you don't wish to convert boundary faces.
--> FOAM Warning :
    Found boundary face (in patch wallsolid) in faceZone baffles1 to convert to baffle patches fluidcold_to_solid/solid_to_fluidcold
Converted 33763 faces into boundary faces in patches
2
fluidcold_to_solid
solid_to_fluidcold
--> FOAM Warning :
    From function int main(int, char**)
    in file createBaffles.C at line 822
    Setting field on boundary faces to zero.
You might have to edit these fields.
Writing mesh to 0
End
After changing almost every parameter in the snappyhexmeshdict i found no real progress, which is by now more than frustrating. Also trying to use topoSet and the attempt to use
splitMeshRegions -cellZonesOnly -overwrite
didn't work at all since appearantly the cells are not completely inside a cellZone only.
However i am left with increasing doubt that mabye my stl files are not ideal from the start. Is there anything known regarding issues like this?
Or is there anything fundamentaly wrong with my workflow and/or my snappyHexMeshdict?
Any hint is greatly appreciated and would help me out a lot in the long run!
Have a good one!
Hr_kules is offline   Reply With Quote
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 08:55
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
[snappyHexMesh] Multi Region Meshing bruce OpenFOAM Meshing & Mesh Conversion 12 July 31, 2013 11:09
[snappyHexMesh] multi region with snappyHexMesh vikthor OpenFOAM Meshing & Mesh Conversion 0 August 24, 2012 04:47
