[snappyHexMesh] snappyHexMesh makes too many patches from STL?
Old   April 26, 2022, 18:41
Default snappyHexMesh makes too many patches from STL?
David
dbazz is on a distinguished road
When trying to create a mesh with sHM from an STL file, thousands of patches and regions are generated - too many!
Adding patches for surface regions:
Patch Type Region
model10m;
6 wall model10m_patch0
7 wall model10m_patch1
8 wall model10m_patch2
30000 wall model10m_patch30000
The meshing process should take a few minutes, but when this issue occurs, it can take hours to generate the same mesh.
I found that is issue occurs when an STL is encoded in binary. When the STL is encoded in ASCII, this issue does not occur. To prevent this issue, you can open the mesh in software like AutoCAD Fusion, import the binary STL, and save the STL as ASCII (which you can open with a simple text editor).
I have solved my own problem but I thought I should post the question and solution here, as I could not find anything to help troubleshoot the problem.
dbazz is offline   Reply With Quote
Old   June 22, 2022, 02:05
Clemens Goessnitzer
cgoessni is on a distinguished road
Hi dbazz!
Did you find out what the problem was?
cgoessni is offline   Reply With Quote
Old   June 22, 2022, 10:05
David
Yes - the STL I was working with was in binary format. It needs to be in ASCII format to be friendly with SHM tools
Old   June 22, 2022, 10:56
Clemens Goessnitzer
Okay, I want to stay with the binary format, since it is much faster, smaller in file size and more precise. I can live with the many patches now, since in my case there are only two, and not 10,000s.
Thanks for your answer.
Old   July 13, 2022, 08:54
Clemens Goessnitzer
Update: If you set the attribute to another value than 0, you will get as many patches as you set the number of attributes:
https://bugs.openfoam.org/view.php?id=3860
If you use numpy-stl, you can set the attribute to 0 by
mesh.attr = 0
That resolved my problem.
ascii binary format, patches, regions, snappyhexmesh, stl
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh Dikkeunit OpenFOAM Meshing & Mesh Conversion 0 February 3, 2020 10:46
[snappyHexMesh] Creating baffes with snappyHexMesh BBack OpenFOAM Meshing & Mesh Conversion 0 September 22, 2019 06:10
[surface handling] How to make boundary patches in STL file nzy102 OpenFOAM Meshing & Mesh Conversion 4 January 22, 2018 16:03
[snappyHexMesh] Patch Names in STL file for snappyHexMesh Kattie OpenFOAM Meshing & Mesh Conversion 11 October 18, 2011 12:05
