[Gmsh] gmshToFoam not creating patches but facezones
Old   April 16, 2022, 12:46
Default gmshToFoam not creating patches but facezones
tRock is on a distinguished road
Hello to all,
I designed a geometry in gmsh with two volumes for a multi region simulation (disk inside a square).
However, upon using gmshToFoam two patches of the disk are assigned as a faceSet and the corresponding patch has 0 faces...
I get several instances of
--> FOAM Warning : Not using gmsh face 4(i j k l ) since zero vertex is not on boundary of polyMesh
If I try to import each of them individually, I get no problems.
The gmsh file is attached to the post. (the extension needs to be changed to .geo)
Since this will be for a multi region case. Can I disregard the warnings, and get away with:
splitMeshRegions -cellZones -useFaceZones -overwrite
I would really appreciate the help!
tRock is offline   Reply With Quote
Old   April 22, 2022, 05:18
Can anyone help me with this?
Old   May 30, 2024, 10:03
Default Any luck?
Matias Alberto Aguirre
maguirre is on a distinguished road
Hi @tRock, did you solve this problem? I am having the same and I do not know how to solve it.
maguirre is offline   Reply With Quote
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 23:35
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 15:46
[Gmsh] Patches in GmshToFoam hannes OpenFOAM Meshing & Mesh Conversion 11 March 8, 2013 09:01
Creating patches usinf CFX 4.4 Meshbuild Kev CFX 0 August 30, 2004 20:39
