[snappyHexMesh] Remove external cell generated by blockMesh |
April 1, 2022, 07:22 |
Haroun
Rep Power: 4 |
The system is simply composed of two injectors and a mixing room. I made the blockMesh block slightly bigger than my geometry .stl file. I only want to mesh the inside of my geometry since I am in an internal flow study, but snappyHexMesh meshes everything inside my blockMesh block. Is there a way to remove cells that is part of my blockMesh block in a way that I can only keep cells that compose my .stl geometry ? |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 08:21 |
Error when running BuoyantBoussinesqSimpleFoam | b.simpson | OpenFOAM Running, Solving & CFD | 8 | June 26, 2020 10:18 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 02:40 |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 15:38 |
[blockMesh] Enhanced blockMesh for external aerodynamics | lakeat | OpenFOAM Meshing & Mesh Conversion | 4 | December 10, 2012 14:23 |
