[blockMesh] Inconsistent point locations between block pair 1 and 4 probably due to inconsist |
March 16, 2022, 18:25 |
Alexander Perez
Rep Power: 6 |
Hi, I've been trying to generate a mesh for a NACA 63210 airfoil with points from a fitted Bezier curve. I try to mesh the points directly from the .dat file from airfoil tools and the meshing goes smoothly, but when I try my generated point data it fails. I'm using this python package to help with the generation of the blockMeshDict file:
https://github.com/damogranlabs/clas...master/classes I also include here the bolckMeshDict file, any suggestions as to how I could fix my problem would be great. |
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 | Hengel | OpenFOAM Meshing & Mesh Conversion | 7 | November 15, 2021 23:56 |
inconsistent number of faces between block pair A & B for a quarter of pipe | AmirBaqa1987 | OpenFOAM Pre-Processing | 3 | November 16, 2013 06:15 |
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 | Hengel | OpenFOAM Meshing & Mesh Conversion | 0 | September 15, 2010 09:34 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
