[snappyHexMesh] What should I do if don't want to remove the cells inside/outside .stl boundary?
Old   March 14, 2022, 04:58
Default What should I do if don't want to remove the cells inside/outside .stl boundary?
Tong Xin
TongX is on a distinguished road
I want to use SnappyHexMesh to generate mesh for IBM algorithm. So my idea is to turn off "snap" and "addLayers", and only turn on "castellatedMesh". That is, the final result I want is Fig. 5.11 in https://cfd.direct/openfoam/user-gui...snappyhexmesh/. But I don't know how to turn off the function of removing cells....
TongX is offline   Reply With Quote
Old   March 14, 2022, 05:44
M
AtoHM is on a distinguished road
OpenFOAM has that covered. Right at the top, you can specify the steps to run. This should get you the wanted result:
// Which of the steps to run
castellatedMesh true;
snap            false;
addLayers       false;
https://develop.openfoam.com/Develop...ppyHexMeshDict
AtoHM is offline   Reply With Quote
Old   March 14, 2022, 06:52
Tong Xin
thanks very much for your reply! I have tried this, the function of "snap" and "addLayers" will be turned off, but the cells in the immersed boundary will be deleted, that's what bothers me. if I delete the "locationInMesh", there will be Error message. But if I set a point outside the boundary in "locationInMesh", there will also be an error says "Point is not inside the mesh or on a face or edge.".
Old   March 14, 2022, 08:46
M
Ah, you probably need locationsInMesh then: Usage of locationsInMesh (needs the ESI release)
It supports multiple zones and should keep all the cells.
cell removal, snappyhexmesh
chtMultiRegionFoam speed up qwertz OpenFOAM Running, Solving & CFD 8 September 18, 2021 07:16
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
