[snappyHexMesh] Not able to snap Fluid Region properly |
March 2, 2022, 14:59 |
Anonymous
Hi All,
I am currently working on the simulation of water flow in pipe which has Static Mixer.Main aim of the simulation is to estmate pressure drop. I have created geometry using salome and tried to mesh it using snappyHexMesh. However, Static Mixer geometry which should be removed from the BlockMesh is not getting removed properly. In short Snapping is not done properly. I have attached Screenshot of geometry, Portion which should be removed and Resulted mesh. Please suggest me some solution for the meshing |
snap, snapcontrol, snappyhexmesh, staticmixer |
Error when solving p_rgh | bob94 | OpenFOAM | 0 | March 17, 2020 09:12 |
alphat | Wien3 | OpenFOAM Running, Solving & CFD | 22 | August 15, 2019 11:00 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
