[snappyHexMesh] SnappyHexMesh for flow through microfractures |
February 18, 2022, 13:30 |
Morteza
Rep Power: 8 |
Hi Folks,
I am using snappyHexMesh for generating a grid for simulating the laminar flow between microfractures. I have the whole computational domain as a STL file (attached) and a background mesh created by blockMesh, which has a bounding box bigger than the STL file. I have the two following questions: 1. For the locationInMesh, I give a point inside the computational domain. However, the result is a grid with just one cell, with a bounding box much larger that the STL's bounding box. It might be due to the small height between top and bottom surfaces (2.5E-05 m). How can I fix this? The snappyHexMeshDict is also attached. 2. The top and bottom surfaces are rough, with certain Hurst exponent and RMS. Do you think that SHM is capable of generating a grid with an acceptable quality for this? Thank you. |
rough wall, snappyhexmesh 3d |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
