[Salome] mesh distortion in OpenFOAM of a model created in Salome
Old   February 2, 2022, 01:31
Default mesh distortion in OpenFOAM of a model created in Salome
William
4lrdyD is on a distinguished road
hello, I have created an irregular solid in salome 9.7, following this procedure:
  1. I have some points that I need to form a closed 3d shape with, so first I create some triangles and quadrilaterals with these points.
  2. I created a shell with these triangles and quadrilaterals
  3. I created a solid with this shell
  4. I created the mesh using NETGEN 3D and NETGEN 1D-2D algorithms
At first glance everything seems fine (first attachment), but when I clip the mesh distortions appear (second attachment), the same thing happens when I export it to a UNV file and import it into OpenFOAM 2106 (third attachment).
Why is this happening and how to avoid this problem?, thanks in advance.
4lrdyD is offline   Reply With Quote
Old   February 7, 2022, 18:40
William
My points were located very far from the origin, to be more exact one of the points had the coordinate (502460, 8586544, 3592), it seems that this is the reason for the distortion since when I move the points close to the origin, i.e. close to (0,0,0), the distortion disappears. I have tried to configure Salome so that it can create the mesh correctly in the original location, but I have not been able to do it, for now the only solution I have is to move the points closer to the origin, or at least not very far.
distortion, mesh 3d, openfoam 2106, salome
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Salome] Mesh Salome 7.3.0 to OpenFoam Ahadi OpenFOAM Meshing & Mesh Conversion 5 July 1, 2014 11:11
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 11:24
Mesh conversion problem from Salome to openfoam jishnusoni OpenFOAM 15 March 3, 2010 02:53
