[snappyHexMesh] Cellset now size 0
Old   January 24, 2022, 13:22
Question Cellset now size 0
Sudharsan Bharatwaj
bruce21 is on a distinguished road
I am new to using OpenFOAM. I set up an actuator disk simulation by defining a specific set of cells as actuation sources using topoSet. But I have a silly problem coming up with topoSet and snappyHexMesh. I used snappyHexMesh to produce refinement regions inside the domain.
The problem I encounter with this is that, when the refinement levels inside the region 'turbine' is set to 2,5, or 6, topoSet is able to create a cellset called 'actuatordiskcellset' with finite number of cells. But for refinement levels 3 and 4, I am getting a message telling that the number of cells inside the cellset is 0. I tried changing the coordinates inside 'locationInMesh' of snappy very slightly and still didn't succeed. Please let me know if you have any suggestions on how to tackle this problem. I have attached the messages put out in terminal for the cases where refinement levels are 2 and 3 respectively. I have also attached the snappydict and topodict files for your reference.
I also noticed that the size of cellzone is in the order of 1e150 (attached a screenshot) and the volume is mentioned as zero. I thought this might help comprehend the problem in a greater detail.
File Type: jpg Screenshot from 2022-01-24 17-55-07.jpg (72.2 KB, 9 views)
bruce21 is offline   Reply With Quote
Old   January 27, 2022, 05:07
M
AtoHM is on a distinguished road
Hm. My first thought is, that depending on the level, the cell centroids are positioned differently and I assume it selects cells based on the centroid location. Your region appears to be pretty narrow, perhaps it just does not wrap around any cell centroids for these levels but for the working ones it does?
Visualize the ones that work and maybe that tells you more.
AtoHM is offline   Reply With Quote
Old   February 15, 2023, 14:07
Eubo is on a distinguished road
Hi, I am facing the exact same issue where the cellZone sizes are 0 and in the order of 1e+150. Were you able to find a solution?
Eubo is offline   Reply With Quote
cellzoneset, snappy hex mesh, toposetdict, toposetsource
[blockMesh] edges not aligned with or perpendicular to non-empty directions ynos OpenFOAM Meshing & Mesh Conversion 6 March 26, 2020 16:02
Issues with poor performance in faster CPU gian93 Hardware 9 October 29, 2018 14:34
Particle size and Mesh Size; Particle tracking; Suman Sapkota CFX 11 August 12, 2018 20:39
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
