Adrian del Ser
Rep Power: 4 ![]() |
Hi everyone, I'm trying to do a thin plate simulation, and having looked around the internet I have found references to createBaffles and topoSet in order to achieve this. None of those posts actually explain how to set up and run the simulation nor provide examples I could test (I am still quite new to openfoam). I am using a modified blockmesh file (based off the movingCone tutorial) that fills in the gap left by the movingCone with a new block. The thin plate should go where the slanted wall of the moving cone was before. I am therefore looking for a simulation of a slanted flat plate moving from rest.
It is possible that blockMesh is not the best utility for this and that snappyHexMesh would be more adapted, although I have not used it before. I also intend to move this plate vertically as well as rotate it around a certain point on its length during the simulation, although these are to be worked out later. This is in effect a zero thickness airfoil simulation. The blockMeshDict file is as follows (the dynamicMeshDict is so far unchanged from the movingCone tutorial): Code:
FoamFile { format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-7.5 0 0) (-7 0 0) (-3.5 0 0) (0 0 0) (-7.5 0.75 -0.032745707) (-7 0.75 -0.032745707) (-3.5 2 -0.087321886) (0 2 -0.087321886) (-7.5 2.5 -0.10915236) (-7 2.5 -0.10915236) (-3.5 2.5 -0.10915236) (0 2.5 -0.10915236) (-7.5 0.75 0.032745707) (-7 0.75 0.032745707) (-3.5 2 0.087321886) (0 2 0.087321886) (-7.5 2.5 0.10915236) (-7 2.5 0.10915236) (-3.5 2.5 0.10915236) (0 2.5 0.10915236) ); blocks ( hex (0 1 5 4 0 1 13 12) (15 15 1) simpleGrading (1 1 1) hex (2 3 7 6 2 3 15 14) (20 15 1) simpleGrading (2 1 1) hex (4 5 9 8 12 13 17 16) (15 15 1) simpleGrading (1 1 1) hex (5 6 10 9 13 14 18 17) (50 15 1) simpleGrading (1 1 1) hex (6 7 11 10 14 15 19 18) (20 15 1) simpleGrading (2 1 1) /**/ hex (1 2 6 5 1 2 14 13) (50 15 1) simpleGrading (1 1 1) ); edges ( ); boundary ( movingWall { type wall; faces ( /*the line below should become the flat plate ideally*/ /*(5 6 14 13)*/ ); } farFieldMoving { type patch; faces ( (9 17 18 10) ); } fixedWall { type wall; faces ( (3 7 15 3) (7 11 19 15) ); } axis { type empty; faces ( (0 1 1 0) (2 3 3 2) /**/ (1 2 2 1) ); } left { type patch; faces ( (0 0 12 4) (4 12 16 8) ); } farField { type patch; faces ( (8 16 17 9) (10 18 19 11) ); } back { type wedge; faces ( (0 4 5 1) (2 6 7 3) (4 8 9 5) (5 9 10 6) (6 10 11 7) /**/ (1 5 6 2) ); } front { type wedge; faces ( (0 1 13 12) (2 3 15 14) (12 13 17 16) (13 14 18 17) (14 15 19 18) /**/ (1 2 14 13) ); } ); mergePatchPairs ( ); |
blockmesh, createbaffles, toposet |
Simulation of flow over cylinder with a splitter plate in front | jonas365 | OpenFOAM | 1 | July 6, 2017 11:13 |
Natural convection boundary layer simulation over a heated vertical plate | camel | OpenFOAM Running, Solving & CFD | 1 | May 9, 2017 00:27 |
Flat Plate: Simulation is not converging | Luana.M. | OpenFOAM Running, Solving & CFD | 1 | April 14, 2016 01:14 |
droplet simulation over flat plate | openfoam1 | OpenFOAM | 11 | December 16, 2010 08:45 |
simulation of flat plate | cisong | FLUENT | 4 | September 12, 2001 11:10 |
