[snappyHexMesh] SnappyHexMesh issue with face pyramid volume |
December 31, 2021, 03:59 |
Eric Segalerba
Rep Power: 5 |
Hi everybody,
I'm quite a new user to OpenFOAM and I've been fighting for a couple weeks now with the creation of the mesh for a complex geometry.. every time I try to do it, with a lot of settings' tests, I keep reading that, after all the iterations both in the castellation and snapping, I still have some "faces with pyramid volume < 1e-3". I was wondering, how can I improve that? Because I think that causes my solution to diverge at a certain point. Thank you in advance! Regards, Eric |
February 19, 2022, 10:49 |
Rep Power: 8 |
I'm pretty sure the standard pyramid volume thresholds is about e-13, so you could lower it maybe.
From what I could understand, the pyramid volumen threshold is what it sounds like, a warning to tell you if a cell is smaller than that. So if you designed your mesh to have cells smaller than that volume, then you should lower it. However, if you have designed your mesh for your cells to be an order of magnitude higher, and it triggers, then some of your cells are messed up |
castellatedmeshcontrols, complex geometry hex, mesh 3d, snap controls, snappy hex mesh |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Seakeeping Solver:Crashed | akbarbagusd | Fidelity CFD | 0 | November 5, 2021 13:42 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 19:25 |
[snappyHexMesh] snappyHexMesh small pyramid volume control | taeyounk | OpenFOAM Meshing & Mesh Conversion | 2 | July 13, 2017 13:07 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
