[mesh manipulation] TopoSetDict CylinderToCell MeshRegions
Old   December 22, 2021, 08:26
Default TopoSetDict CylinderToCell MeshRegions
Felix
fel44499 is on a distinguished road
Dear Community,
in the last weeks I was looking for a solution to create a moving cylinder in a refined mesh through a bigger mesh. While setting up the case especially the mesh Iīm having quiet some difficulites.
At first blockmeshDict ist used to create the basic, bigger mesh (A).
After that I use TopoSetDict to create a region inside A.
Then I set up my cylinder in a subsetMesh with "subsetMesh cylinder -patch hole -overwrite". Basically a cylindershaped form is being cut out.
Afterthat i run topoSet again and finally I create different cellIDs with setFields.
My Problems are:
a) The cylinder itself has cells from the bigger overall mesh, see Image 1, what is not wanted.
b) The contour of the clinder is in steps, not like a nice arch like in blockMesh.
It canīt be that complicated, but I just canīt figure it out myself.
Maybe some of you knows how to solve this.
Thanks,
Felix
fel44499 is offline   Reply With Quote
cellid, cylindertocell, toposetdict
topoSetDict error (for overtopping) deoga OpenFOAM Pre-Processing 2 August 21, 2022 07:24
Creating an Angled, Smooth Wall with topoSetDict JakeAC OpenFOAM Pre-Processing 1 July 25, 2020 22:37
topoSetDict samiam1000 OpenFOAM 5 July 23, 2019 12:45
Oscillating cylinderTocell Field with topSetDict in openFoam Ben UWIHANGANYE OpenFOAM Programming & Development 2 June 25, 2018 02:19
topoSetDict error JohnJohn8 OpenFOAM Pre-Processing 1 August 3, 2016 06:20
