[Commercial meshers] ICEM>OpenFOAM: faceTets error |
December 16, 2021, 08:47 |
Christoph
Rep Power: 5 |
Good day all,
My problem is related to Ansys ICEM, the conversion to OpenFOAM and checkMesh errors. I have made a hexahedral mesh in ICEM CFD 18.1 (single wind turbine rotor blade, see. Fig.1/2) with about 7M cells. After conversion too OpenFOAM (fluent3DMeshToFoam) everything seems fine, checkMesh -allTopology gives the following output though: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 7067496 faces: 20959026 internal faces: 20715676 cells: 6945947 faces per cell: 5.99985891 boundary patches: 7 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 6944967 prisms: 980 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box BLADE 36744 36839 ok (non-closed singly connected) (-1.80496822 -0.944902034 1.47313936) (0.982712077 0.944827568 35.01) INLET 32929 33300 ok (non-closed singly connected) (-103.92305 -90 0.875) (103.92305 -90 119.998012) HUB 31215 31643 ok (non-closed singly connected) (-1.51554446 -90 0.875) (1.51554446 350 1.74999999) OUTLET 32929 33300 ok (non-closed singly connected) (-207.8461 350 0.875) (207.8461 350 239.99482) SIDE_LEFT 44421 44844 ok (non-closed singly connected) (-207.8461 -90 0.875) (-1.51554441 350 120) SIDE_RIGHT 32929 33300 ok (non-closed singly connected) (1.51554441 -90 0.875) (207.8461 350 120) TOP 32183 32498 ok (non-closed singly connected) (-207.8461 -90 60) (207.8461 350 239.99482) Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology Bounding box int_FLUID 20715676 7067488 multiply connected (shared edge) (-206.631866 -90 0.875) (206.655689 350 239.99482) <<Writing 7065113 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox FLUID 6945947 7067496 15472908.6 (-207.8461 -90 0.875) (207.8461 350 239.99482) Checking geometry... Overall domain bounding box (-207.8461 -90 0.875) (207.8461 350 239.99482) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (8.53833983e-17 -5.91260289e-16 6.12398899e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 15610.2635, number of cells 4324 <<Writing 4324 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 1.96668796e-09. Maximum face area = 209.596829. Face area magnitudes OK. Min volume = 4.13112397e-12. Max volume = 1052.66242. Total volume = 15472908.6. Cell volumes OK. Mesh non-orthogonality Max: 89.825889 average: 18.8627287 *Number of severely non-orthogonal (> 70 degrees) faces: 15644. Non-orthogonality check OK. <<Writing 15644 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 3.18585766 OK. Coupled point location match (average 0) OK. ***Error in face tets: 106564 faces with low quality or negative volume decomposition tets. <<Writing 106564 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces *Edges too small, min/max edge length = 2.34169721e-06 21.8345617, number too small: 837655 <<Writing 837655 points on short edges to set shortEdges <<Writing 837657 near (closer than 0.000650828928 apart) points to set nearPoints *There are 6 faces with concave angles between consecutive edges. Max concave angle = 89.3707312 degrees. <<Writing 6 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.612468465 average = 0.999992307 *There are 8 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.612468465 <<Writing 8 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 5.08273978e-15 average: 0.0490945013 ***Cells with small determinant (< 0.001) found, number of cells: 2334747 <<Writing 2334747 under-determined cells to set underdeterminedCells Concave cell check OK. Face interpolation weight : minimum: 0.000349430852 average: 0.479246783 ***Faces with small interpolation weight (< 0.05) found, number of faces: 5365 <<Writing 5365 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.000318593433 average: 0.913266952 ***Faces with small volume ratio (< 0.01) found, number of faces: 2448 <<Writing 2448 faces with low volume ratio cells to set lowVolRatioFaces Failed 5 mesh checks. End Code:
***Error in face tets: 106564 faces with low quality or negative volume decomposition tets. The faceSet lowQualityTetFaces is visualised in Figures 3/4 (most of the faces are on the blade surfaces), i dont understand why there would be Tet-Faces since they should be hex. Why is OpenFOAM even decomposing into tets? Does anyone have an idea why this error occurs? Something must have happend converting the mesh. ICEM: Mesh Check finds some penetrating and overlapping elements (it doesnt seem like they are the cause for this), all cell determinants are above 0.1, Quality for 99.96% of elements above 0.4. using OpenFOAM-v1912 any help is much appreciated, if more info is needed - let me know! best regards christoph |
December 16, 2021, 20:10 |
Hrvoje Jasak
Rep Power: 33 |
Yet decomposition is done because this is how you calculate the cell volume and cell centre for a polyhedron. It means that some of the faces are ciccave, but I’d like to see precisely how. Can I have a look at this mesh? You can contact me on h.jasak at wikki.co.uk Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
December 17, 2021, 10:27 |
Christoph
Rep Power: 5 |
Thanks for your quick response. Of course you can have a look, i have already messaged you.
Christoph |
December 17, 2021, 17:15 |
Hrvoje Jasak
Rep Power: 33 |
Not received - can you try again please?
June 18, 2022, 07:46 |
Sakun
Rep Power: 6 |
hi guys,
any recommendation for this issue ? because i am having the same many thanks |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
