[CAD formats] OpenFOAM Fatal Error - Unknown file extension STL?!
Old   November 23, 2021, 12:02
Default OpenFOAM Fatal Error - Unknown file extension STL?!
William Peace
WJPeace1 is on a distinguished road
Hi all,
I am currently in the process of learning OpenFOAM (also using the HELYX-OS GUI), and doing a simple internal pipe flow problem to familiarize myself with the code. Upon trying to generate the mesh using the simple blockMesh command, I get the following error:
--> FOAM FATAL ERROR:
unknown file extension STL. Supported extensions are '.ftr', '.stl', '.stlb', '.gts', '.obj', '.ac', '.off', '.nas', '.tri' and '.vtk'
The pipe which I generated in SolidWorks has been exported as a STL file, and therefore I am unsure why this error is occurring.
Any help would be greatly appreciated!
WJPeace1 is offline   Reply With Quote
Old   November 23, 2021, 12:11
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
try renaming it with lower-case "stl" - should work
olesen is offline   Reply With Quote
Old   November 23, 2021, 13:06
William Peace
This worked! Thanks for your help!
openfoam-5.0, stl
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 Yage OpenFOAM Community Contributions 18 February 15, 2016 03:02
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
