[snappyHexMesh] Cannot find patchField entry for *** |
November 19, 2021, 04:35 |
Rep Power: 4 |
Hi, I'm trying to run a bike simulation using the motorbike tutorial as a starting point. I've successfully run it on a single core and I'm now trying to run it in parallel on 6 cores,
The procedure I follow is: surfaceFeatures blockMesh decomposePar mpirun -np 6 snappyHexMesh -parallel -overwrite After that I tried to run simpleFoam but it was stopping saying it couldn't find patchField Frame in processor*/0/p. I looked in the logs of patchSummary and it had the same error about the patchField. In the snappyDict I created 3 different regions (frame and wheels) in order to have the wheels in rotation. snappyHexMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { bike { type triSurfaceMesh; file "Bike.stl"; regions { Front { name Front; } Rear { name Rear; } Frame { name Frame; } } } refinementBox { type searchableBox; min (-1.0 -0.7 0.0); max ( 8.0 0.7 2.5); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 100000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 2000000; // The surface refinement loop might spend lots of iterations refining just a // few cells. This setting will cause refinement to stop if <= minimumRefine // are selected for refinement. Note: it will at least do one iteration // (unless the number of cells to refine is 0) minRefinementCells 10; // Allow a certain level of imbalance during refining // (since balancing is quite expensive) // Expressed as fraction of perfect balance (= overall number of cells / // nProcs). 0=balance always. maxLoadUnbalance 0.10; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 3; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/geometry for now. features ( { file "Bike.eMesh"; level 6; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { bike { level (6 7); regions { Front { level (6 7); //Optional specification of patch type (default is wall). No //constraint types (cyclic, symmetry) etc. are allowed. patchInfo { type wall; inGroups (bikeGroup); } } Rear { level (6 7); patchInfo { type wall; inGroups (bikeGroup); } } Frame { level (6 7); patchInfo { type wall; inGroups (bikeGroup); } } } } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { refinementBox { mode inside; level 4; } } // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (3.0001 3.0001 0.43); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 3; //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 2.0; //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Feature snapping //- Number of feature edge snapping iterations. // Leave out altogether to disable. nFeatureSnapIter 10; //- Detect (geometric only) features by sampling the surface // (default=false). implicitFeatureSnap false; //- Use castellatedMeshControls::features (default = true) explicitFeatureSnap true; //- Detect points on multiple surfaces (only for explicitFeatureSnap) multiRegionFeatureSnap false; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes true; // Per final patch (so not geometry!) the layer information layers { "(lowerWall|Bike).*" { nSurfaceLayers 1; } } // Expansion factor for layer mesh expansionRatio 1.0; // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.3; // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.1; // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 60; // At non-patched sides allow mesh to slip if extrusion direction makes // angle larger than slipFeatureAngle. slipFeatureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 3; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 10; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { #include "meshQualityDict" } // Advanced // Write flags writeFlags ( scalarLevels layerSets layerFields // write volScalarField for layer coverage ); // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9 Exec : patchSummary -parallel Date : Nov 19 2021 Time : 09:53:35 Host : "marco-desktop-ubuntu" PID : 4293 I/O : uncollated Case : /home/marco/OpenFOAM/marco-9/run/Bike/bike nProcs : 6 Slaves : 5 ( "marco-desktop-ubuntu.4294" "marco-desktop-ubuntu.4295" "marco-desktop-ubuntu.4296" "marco-desktop-ubuntu.4297" "marco-desktop-ubuntu.4298" ) Pstream initialised with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Valid fields: volScalarField thickness [1] [1] [1] --> FOAM FATAL IO ERROR: [1] Cannot find patchField entry for Frame [1] [1] file: /home/marco/OpenFOAM/marco-9/run/Bike/bike/processor1/0/nut/boundaryField from line 25 to line 70. [1] [1] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [1] in file /home/marco/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. [1] FOAM parallel run exiting [2] [2] [2] --> FOAM FATAL IO ERROR: [2] Cannot find patchField entry for Frame [2] [2] file: /home/marco/OpenFOAM/marco-9/run/Bike/bike/processor2/0/nut/boundaryField from line 25 to line 63. [2] [2] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [2] in file /home/marco/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. [2] FOAM parallel run exiting [2] [4] [4] [4] --> FOAM FATAL IO ERROR: [4] Cannot find patchField entry for Frame [4] [4] file: /home/marco/OpenFOAM/marco-9/run/Bike/bike/processor4/0/nut/boundaryField from line 25 to line 70. [4] [4] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [4] in file /home/marco/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. [4] FOAM parallel run exiting [4] [5] [5] [5] --> FOAM FATAL IO ERROR: [5] Cannot find patchField entry for Frame [5] [5] file: /home/marco/OpenFOAM/marco-9/run/Bike/bike/processor5/0/nut/boundaryField from line 25 to line 58. [5] [5] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [5] in file /home/marco/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. [5] FOAM parallel run exiting [5] [0] [0] [0] --> FOAM FATAL IO ERROR: [0] Cannot find patchField entry for Frame [0] [0] file: /home/marco/OpenFOAM/marco-9/run/Bike/bike/processor0/0/nut/boundaryField from line 25 to line 58. [0] [0] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [0] in file /home/marco/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. [0] FOAM parallel run exiting [0] [1] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] Cannot find patchField entry for Frame [3] [3] file: /home/marco/OpenFOAM/marco-9/run/Bike/bike/processor3/0/nut/boundaryField from line 25 to line 63. [3] [3] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] [3] in file /home/marco/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. [3] FOAM parallel run exiting [3] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 3 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [marco-desktop-ubuntu:04289] 5 more processes have sent help message help-mpi-api.txt / mpi-abort [marco-desktop-ubuntu:04289] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
November 25, 2021, 04:33 |
Rep Power: 4 |
I managed to "solve" this problem by running decomposePar, snappyHexMesh in parallel, reconstructParMesh -constant, delete the 0 folder from the processor* folders, and force decomposePar again.
If anyone has a suggestion to overcome it without this decompose,delete files, decompose again dance let me know. Cheers |
November 25, 2021, 10:06 |
#3 | |
Mark Olesen
Rep Power: 40 |
Some of the root problems are discussed in this issue: https://develop.openfoam.com/Develop.../-/issues/2236 The upshot is that either you need to do a reconstructParMesh to establish proper parallel<->serial mappings for decompositions. Or you need to define your initial (serial) boundary conditions with the constraint types defined as regexs and then simply copy them into the decomposed 0/ directories. |
Cannot find patchField entry for InletWall | range_rover | OpenFOAM Running, Solving & CFD | 5 | November 18, 2020 21:21 |
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 | hconel | OpenFOAM Pre-Processing | 0 | October 5, 2018 17:22 |
decomposePar fails "Cannot find patchField entry for maxY" | JasonQuinn | OpenFOAM Pre-Processing | 2 | April 4, 2017 01:07 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
A stupid question | luckyluke | OpenFOAM Running, Solving & CFD | 14 | August 13, 2007 04:25 |
