[blockMesh] blockMeshDict.m4 for cylinder tanks |
foilcat
Rep Power: 0 ![]() |
Dear foamers,
I've been working on some kind of sloshing cylinder tank including water, and came across a major problem. I can easily run blockmesh by using the m4 processor, but unfortunately, the water disappears somehow in the end. If I guess right, the problem is mainly on defining wall type in m4 and 0/alpha.water.orig,U,p files. Any advice is highly appreciated! Thanks ![]() |
block mesh, macros of meshing, sloshing tank, wall boundary conditions |
Coupling Analysis of the ship model with tanks for sloshing analysis in ANSYS | Mostafa CFD | ANSYS | 0 | January 30, 2021 04:48 |
Equalizing Pressure between Two Tanks | cwl6750084 | FLUENT | 6 | April 14, 2020 06:39 |
how to connect two tanks with pump? | Johnr | FLUENT | 0 | May 18, 2016 13:37 |
k-epsilon model for stirred tanks | Parag Shah | Main CFD Forum | 3 | June 22, 2013 15:24 |
Problem in specifying the boundary condition for tank's surface which is on fire | BHE | FLUENT | 1 | March 21, 2013 23:02 |
