[blockMesh] Best way to get a hex mesh on a abrupt cross-section change |
November 9, 2021, 13:15 |
Tencho
Rep Power: 11 |
Hello, everyone.
I am working on the mesh for a baffled column (see attached image). I am using swiftblock to create the blockMeshDict. I would like to keep it 100% hex mesh (or as close as possible), but I am struggling on how to deal with the abrupt diameter change at the baffle. I know there are ways to introduce infinitely thin baffles, but that would not work for me because I need the angled surface on the top face. Would I have to merge faces at the baffle in order to maintain the hex mesh, or is there a better way? I also thought of having a very shallow angle (almost horizontal) on the bottom side of the baffle, but I'm afraid that would give me very skewed cells. Any thoughts would be appreciated. |
block mesh, openfoam, swiftblock |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 08:11 |
[blockMesh] Blockmesh error - 2D scramjet | ishaninair | OpenFOAM Meshing & Mesh Conversion | 7 | March 18, 2011 00:14 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
