[blockMesh] rectangular prism with a hole on one of its face which acts as inlet |
October 6, 2021, 16:03 |
How do I create a rectangular prism with a hole on one of its faces which acts as an inlet in a multiphase problem? the rectangular prism dimensions are 5 *5 *50 and the hole in on the centre of the 5 *5 face and its diameter is 0.5 mm.
I have to then mesh it. The geometry is then to be meshed by a Cartesian grid of 0.15mm increments on the z direction( 50 mm axis). On the x-y plane, the same mesh size is used in a mapped mesh form in order for the mesh to form the shape of the orifice cross section. How do I do this? Please help. |
October 7, 2021, 13:34 |
Sami Safarini
Rep Power: 5 |
Does this hole in your case also require a mesh? So you would have two different materials?
October 7, 2021, 13:37 |
Yes the hole requires a mesh as well. It acts as an inlet so no, there are not two different materials
hole, mapped mesh, multiphase flow, openfoam, rectangular prism |
FLUID THROUGH A HOLE (2D) interFoam | AmélieO | OpenFOAM Running, Solving & CFD | 0 | January 17, 2018 18:25 |
hole in rectangular object... | karthik | FLUENT | 2 | May 23, 2013 23:39 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
Draw and export a face (inlet) in GAMBIT | Kim | FLUENT | 3 | September 6, 2004 08:06 |
