[Other] toposet only working when origin is inside the defined zone in the box |
August 4, 2021, 04:06 |
walter white
Rep Power: 5 |
Hello
I have created a mesh using blockmesh and i am trying to split the regions using toposet. But toposet is not showing any cells unless origin is inside the defined region. in my geometry there is a cylinder with its center on x axis at distance equal to the circle's radius from origin When the cylinder definition in toposet is equal to radius (touching origin) then it is detecting elements When i reduce the cylinder radius by 1mm it is showing 0 elements i am new to openfoam please help Thank you in advance |
August 4, 2021, 06:00 |
walter white
Rep Power: 5 |
Never mind
i was using scale 0.001 but apparently i have to write the lengths in mks itself. now its working |
blockmeshdict, toposetdict |
Porosity profile, dividing a zone, or getting zone location from zone | khoopes | FLUENT | 0 | June 2, 2012 20:39 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 18:51 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
