[mesh manipulation] Adaptive Mesh Refinement - maxCells |
Rep Power: 5 ![]() |
Hi OpenFOAMers!
I recently implemented adaptive mesh refinement to my simulation using rhoCentralFoam solver. However, I encounter problem with the maximum number of cells that the AMR generates. My 'base' mesh has ~ 1e6 cells. And I want to refine the field up to ~ 2e6 cells. However, during the simulation it went up to nearly 8e6 cells! One of the messages prompted by OpenFOAM: Selected 777925 cells for refinement out of 2269126. Refined from 2269126 to 7714601 cells. Here is my dynamicMeshDict: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicRefineFvMesh; // How often to refine refineInterval 1; // Field to be refinement on field MachGradMag; // Refine field in between lower..upper lowerRefineLevel 1e4; upperRefineLevel 1e6; // If value < unrefineLevel unrefine unrefineLevel 1e8; // Have slower than 2:1 refinement nBufferLayers 3; // Refine cells only up to maxRefinement levels maxRefinement 5; // Stop refinement if maxCells reached maxCells 2278148; // twice the base mesh // Flux field and corresponding velocity field. Fluxes on changed // faces get recalculated by interpolating the velocity. Use 'none' // on surfaceScalarFields that do not need to be reinterpolated. correctFluxes ( (neg none) (pos none) (phi none) ); // Write the refinement level as a volScalarField dumpLevel true; End of dynamicMeshDict Could you guys help me out understand why OF is doing what it is doing? Is it something to do with buffer layers and maximum refinement? Thanks! |
Volkan Atar
Rep Power: 3 ![]() |
Hello have you figured it out why it is like that? I am having exactly the same problem with a steady state solver.
Thanks |
dynamicmeshdict, dynamicmeshfvmesh |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
Data mapping with Adaptive Mesh Refinement | kapten_zoom | STAR-CCM+ | 0 | June 7, 2021 09:28 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
