[blockMesh] Error while creating blockMesh for cylinder in OpenFOAM
Old   July 27, 2021, 09:42
Question Error while creating blockMesh for cylinder in OpenFOAM
Malte Radecke
malteradecke is on a distinguished road
Hello Community,
I'm relatively new to OpenFOAM and right now I'm trying to create the mesh for a 2D-cylinder tutorial. After entering the "blockMesh" command in the main folder of the case "cylinder" I get the following error:
| \\ / O peration | Version: 2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _79e353b8-20201222 OPENFOAM=2012
Arch : "LSB;label=32;scalar=64"
Exec : blockMesh
Date : Jul 27 2021
Time : 11:57:10
Host : a2faadc13a8e
PID : 834
I/O : uncollated
Case : /home/ofuser/workingDir/runCasesOF/exFromCourse/withMirrorMesh
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from "system/blockMeshDict"
Using #calc at line 24 in file "/home/ofuser/workingDir/runCasesOF/exFromCourse/withMirrorMesh/system/blockMeshDict"
Using #codeStream with "/home/ofuser/workingDir/runCasesOF/exFromCourse/withMirrorMesh/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_64c7a173633041f6426097f4b4042e201932 58ef.so"
Could not load "/home/ofuser/workingDir/runCasesOF/exFromCourse/withMirrorMesh/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_64c7a173633041f6426097f4b4042e201932 58ef.so"
/home/ofuser/workingDir/runCasesOF/exFromCourse/withMirrorMesh/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_64c7a173633041f6426097f4b4042e201932 58ef.so: cannot open shared object file: No such file or directory
Creating new library in "dynamicCode/_64c7a173633041f6426097f4b4042e20193258ef/platforms/linux64GccDPInt32Opt/lib/libcodeStream_64c7a173633041f6426097f4b4042e201932 58ef.so"
Invoking wmake libso /home/ofuser/workingDir/runCasesOF/exFromCourse/withMirrorMesh/dynamicCode/_64c7a173633041f6426097f4b4042e20193258ef
--> FOAM FATAL ERROR: (openfoam-2012)
exec(wmake, ...) failed
From int Foam::system(const Foam::CStringList&, bool)
in file POSIX.C at line 1628.
FOAM exiting
Segmentation fault
It seems that there is trouble creating some part of the dynamic code, which later should be used. I searched for this problem on the internet and the CFD-Online forum but couldn't find anything. The cavity example works fine, only with cylinder I have troubles. I would appreciate some help a lot!
Some information of my system: I'm using macOS Big Sur 11.4, the Docker App (Docker Inc., v0.9.1-beta3) and the OpenFOAM v2012.
Best regards
Malte
malteradecke is offline   Reply With Quote
blockmesh cylinder, openfoam2012
OpenFoam restarting simulation, stops at first Time loop syntex OpenFOAM Running, Solving & CFD 4 April 5, 2019 12:20
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[blockMesh] Error while creating blockMesh: Inconsistent point locations between block pair lpashwin OpenFOAM Meshing & Mesh Conversion 2 June 1, 2015 13:31
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
