[snappyHexMesh] Fixing holes in snappyhexMesh coarse grid |
Horst van Gras
Rep Power: 7 ![]() |
I'm using OpenFoam2012 and needs a coarse grid for a mesh study, but sHM is creating some holes at the STL geometries (see attached immage), which results in wrong patches when using splitMultiRegions. Which smooth mechanism would be the best to fix that kind of holes. Thx in advance! |
Erick D. Martinez
Rep Power: 5 ![]() |
Ive found that when this happens to me, it is because the STL file is made from coarse triangles, try and look at your STL files and try refining the geometry further.
holes, snappy hex mesh |
IBM grid recognition in foam-extend 4.1 | Guanzhu | OpenFOAM | 0 | January 25, 2021 21:23 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Time step high or low for coarse grid, courant number high or low?? | sameer22 | Fluent Multiphase | 2 | December 30, 2015 00:41 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
Algebraic Multigrid for nonuniform grid | Joshua Lee | Main CFD Forum | 4 | March 16, 2000 13:05 |
