July 22, 2021, 13:53 |
illegal faces
Charles Rymal
I start with a rectangular block mesh and have a stl file that defines a boundary between solid and fluid within that rectangular region.
My snappyHexMeshDict is: Code:
castellatedMesh true; snap true; addLayers true; geometry { solid_to_fluid { type triSurfaceMesh; file "solid_to_fluid.stl"; } }; castellatedMeshControls { refinementSurfaces { solid_to_fluid { level (3 4); faceZone solid_to_fluid; cellZone solid; cellZoneInside insidePoint; insidePoint (0.0 0.0 0.0); } } nCellsBetweenLevels 1; refinementRegions {} locationInMesh (-0.019 0.0 0.0); } snapControls { nSmoothPatch 3; } addLayersControls { relativeSizes true; minThickness 1; finalLayerThickness 1; expansionRatio 1; layers {} } meshQualityControls { maxNonOrtho 65; } Code:
Checking faces in error : non-orthogonality > 65 degrees : 13930 faces with face pyramid volume < 1e-13 : 1585834 faces with concavity > 80 degrees : 0 faces with skewness > 4 (internal) or 20 (boundary) : 0 faces with interpolation weights (0..1) < 0.05 : 0 faces with volume ratio of neighbour cells < 0.01 : 0 faces with face twist < 0.02 : 0 faces on cells with determinant < 0.001 : 0 Finished meshing with 1599764 illegal faces (concave, zero area or negative cell pyramid volume) When I try to run the solution (conjugate heat transfer), the solver stops saying that it encountered a negative temperature. So the solution seems to be diverging and I'm wondering if its because of a bad mesh. I appreciate your help! |
April 12, 2023, 04:49 |
#2 | |
Farzad Faraji
Rep Power: 7 |
Dear Charles
did you find what is illegal faces means? I also have illegal faces after I do SHM but when I check the mesh using checkMesh everything seems fine. I have attached the figure to the post. Thanks, Farzad Quote:
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
